How do sealed liquid cooling systems work?
​Yes another self explanatory titled one so how do sealed liquid cooling systems work?
Such as the ones included with Origin PC's seen here:
http://www.originpc.com/configurator/d/d4.aspx?SYSTEMID=2
If that link isn't helpful ask me to change it.
Thanks,
- regards
- DrV
https://linustechtips.com/topic/72132-how-do-sealed-liquid-cooling-systems-work/
Exactly like custom watercooling systems but they come pre-built and usually consist of much lower quality components.
It's just a posh name for AIOs. The one's on Origin PC sound like the grabed some cheap components and put fancy names on them.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
Thanks,
- regards
- DrV
its just a sealed loop as it says, with the pump on the cpu block, usually much much cheaper then any other water cooling solution
The Beast [Case -  Corsair 750D CPU - I5 4670k @ 4.3ghz 1.2V CPU cooler - Hyper 212 evo Mobo - MSI g45 z87 RAM - G.Skill Z series 4*4@1866mhz GPU - Gigabyte windforce 3x r9 290 Storage - SSD, samsung 840 evo 120gb HDD, Western Digital Blue 1tb PSU - SilverStone Strider silver 80+ 750WPeripherals [Monitor - ASUS VS239 IPS 23" Keyboard - Corsair K95 Mouse - Mad Catz RAT 7]
What I would love to know... with custom loops you need to top-up coolant and its advised you change the full loops coolant yearly as the liquid breaks down over time and looses it effectiveness.....
then how do closed looped systems performance 2-3 years after being bought:? I assume the coolant must also break down... so do they become junk quickly?
Quack 🦆
Well to answer your question directly, it's a system that consists of a pump, tubing, and a radiator all connected and unable to be removed. It's a useful tool for people who are terrified to make their own loop (me). They are maintenance free and cool very well :)
CPU Overclocking Database <------- Over 275 submissions, and over 40,000 views!
GPU Overclocking Database
I assumed so. I'm confident enough to do my own however to ignorant at this point. Can anyone recommend one of Linus's videos that provides the best information on building your own liquid cooled rig for those like me willing to go DIY?
I didn't anticipate this much of a response from everyone. Really starting to love these forums. Thanks, keep it up! :D
P.S
Would it be a better performance and financial decision to go with say Overclockers UK and buy a rig from them? They have a custom configurator just like Origin.
Go to the two stickys at the top of this forum section. They will answer a lot fo your questions.
They are sealed so no dust or particiles can get inside. They also have "special" coolant.
They last around as long as the warranty.
Don't even know originPC was a real thing. I just hope this isn't going to be an other overpriced alienware kind of hype.
You're probably spot on. This is why I've raised the subject. What are your opinions on Overclockers UK and their builds? They also have a custom configurator like Origin.
Thanks Ghost, many thanks. Maybe should've in the first place, but hey I've enjoyed this thread. :)
