Easiest thing to do is run cinebench r15 at stock, then at OC.
You could use Unigine Heaven
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
25 minutes ago, AngryFishLady said:
Hello everyone ! I'm looking for a software to be able to have a number to put on my CPU performance and see how much I'm gaining by running higher clock frequencies.
Just for clarity, you're looking for CPU performance, not IPC. IPC isn't a word for "CPU performance". IPC is performance per GHz. If your CPU is at 3.0 GHz or 5.0 GHz it will still have the same IPC even though the performance will be higher.
Heaven, Valley, etc. are GPU benchmarks. They could tell you if your CPU was getting in the way of your GPU, but I'm not sure how bad your CPU would have to be for that to happen. I've only ever seen GPUs hit ~100% in Heaven runs.
What you want to compare overclocks is Cinebench.
2 hours ago, AngryFishLady said:
Why specifically single core ?
Well if you want to compare single core performance improvements (vast majority of programs/games out there are single core) then you will want to see that improvement?
Quack 🦆
