Beside Crucial Ballistix Tracer RAM which is able to change it to Blue lightings. Which other brands has LED ram ? Looking for blue in colour
Chassis: Corsair 540 AIR | CPU: i5 4670k @ 4.5Ghz | Motherboard: Z87 Sabertooth | GPU: Asus GTX 780 Direct CU IIRAM: 16GB Avexir Core Series 1866mhz Blue LED | SSD: Samsung EVO 250GB HDD: Western Digital 1TB Blue | Coolers: Corsair H100i
Build Log: Project Sapphire
https://linustechtips.com/topic/71824-led-ram/
corsair dominator platinums with the lightbar attachment?
https://linustechtips.com/topic/71824-led-ram/#findComment-983488
Dominator Platinum which have attachments you can buy that are blue
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/71824-led-ram/#findComment-983492
