CPU fan not spinning
Solved by Ryoku,
50 minutes ago, MrAlbertrocks said:Well, the problem is solved as long as AI Suite is active, but i find it strange that the fans will simply stay idle even though the CPU is getting dangerously hot. That should not happen, ever, even if there's no software controlling it. That's why i wanted people to shed some light, i already solved the issue, but i would like to know WHY does the CPU fan stays idle even though the CPU is extremely hot. There should be a default profile, but IDK.
Yea that is pretty weird there should be a default fan profile in your bios that should have taken over when you closed AI Suite, I'm guessing its a conflict with Corsair and Asus' software.
