Noctua NF-A14 PWM and NF-A14 FLX - difference?
ThomJV
39 minutes ago, LoGiCalDrm said:
Yes. Hub imitates PWM fan so mobo thinks its controlling PWM fan. It will still be one speed for all fans connected to hub. Versus having 2-3 mobo headers with different fan curves (so you could have intakes and exhaust going different speeds).
For the hub 3pin/FLX is best. Places for headers seem spacious to fit PWM too. But control will be only with 3 fans.
And could I still connect 4pin fans to the 3pin connectors on the hub aswell?
If they physically fit, yes. From pic it looks like they could fit. But without hub at hand, its hard to say for sure.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Alright, thanks for the info! This helped me out a lot!
On 5-1-2017 at 11:04 AM, Aereldor said:
Measure it. Measure the space between the PSU and shroud, and the space between the shroud and GPU. You may be right, but you can't be certain until you know exactly how much space there is. If it's an inch or more, I don't think it'll pose any problems.
Also, you could get an SFX power supply, which will allow for a lot more room. However, very few of the Enthoo Evolv builds I've seen have blower-style cards in them.
On 5-1-2017 at 11:19 AM, ThomJV said:
This image shows it really well, space is minimal (not my own image, don't yet have the GPU, the specs above is my planned build)
This is the reason why I think a blower-fan card will be better.
So what are your thoughts? Enough space?
No, that doesn't look like a lot, especially if you use a regular ATX power supply. I'm willing to take @tmcclelland455's word for the temperature issue, but the Founders' Edition card will still be noisier.
