is the power connectors on the GPU plugged in?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
6 minutes ago, Rock04 said:
Hopefully working, restarting computer after update
is there a free benchmark test
Unigine Heaven
