I'm thinking about getting a new case to replace the generic box my pc is currently in and my main criteria is quietness. Not overly fussed about airflow as my i5 6600k doesn't get very hot but I do need a case that looks good for under 100 pounds ($120).
If anyone has any ideas I would be happy to hear them.
https://linustechtips.com/topic/713955-looking-for-a-quiet-pc-case/
1 minute ago, JordanMihailov said:
That's my problem, a lot of those cases look really ugly in my opinion. Saying that, I do like the look of the h440 - seems like a very nice case
3 minutes ago, PCGeek said:
Fractal Design Define series are my go to cases for silence.  bequiet! Dark Base Pro 900 is also good.
I agree the Define C looks really nice and looks reasonably quiet but the dark base is just a little too expensive
I think pretty much any case is quiet at idle, as long as the fan itself aren't loud. I have temper case(460x) at the moments and the noise different from R5 won't noticeable at load as well. I have notcua fans for AIO and custom fan curve for rest of the case fan which won't allow them to go over 50% which keep the noise down.
Magical Pineapples
The Cooler Master Silencio 352 is great. It even has a built-in SD card reader.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
phanteks eclipse p400s ?
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
