Im looking into buying a new hard drive. I have gone through 4 hard drives this year and they all keep failing. i have a lan rig so my pc gets moved a lot and my desk i have is wiggly. So if anyone can reccomend me a hard drive that isnt poop than let me know. And yes i know buy an ssd. I have one but i need a mass storage hard drive
https://linustechtips.com/topic/713799-hard-drive-question/
I would buy a WD Red as you said your desk is "wiggly". The vibration resistance and 24/7 performance may benefit you.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/713799-hard-drive-question/#findComment-9103278
Either that or a Seagate Ironwolf drive, both made for NAS usage. Afaik the Ironwolf drives are at 7200RPM, whereas the WD Reds are at 5900RPM or something around that... feel free to correct me on that xD
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/713799-hard-drive-question/#findComment-9103294
A WD Red drive would be "good enough" I guess...
But if you really want something that last forever even if you were to launch it across the street, you'd need a SSD.
https://linustechtips.com/topic/713799-hard-drive-question/#findComment-9103302
Mass Storage as in my steam Library. I have 800+ gigs of steam games i want to throw on it. And i know the Red drives are 5400rpm so i dont really want to go with that option
https://linustechtips.com/topic/713799-hard-drive-question/#findComment-9103516
Rotation speed has very little effect on drive performance. The Red will do much better thanks to platter density, controller throughput, cache, and scheduling performance.
https://linustechtips.com/topic/713799-hard-drive-question/#findComment-9103527
