Just got a EVGA Z170 FTW and I now have 7 4 pin fan headers. Im tired of my somewhat loud system, and would like to slow my fans down. Anyone know really quiet 4 pin pwm fans that arent to expensive? I have 2 NF-F12's currently. Don't mind using reducers. I need some for the front of my H440 (So 3 120's or 2 140's) and one for the back (140)
Breaking things 1 day at a time
https://linustechtips.com/topic/711900-what-fans-to-get/
Noctua fans, i also hear good things about the ML fans from corsair.
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9085396
bequiet! fans aren't too expensive and they are whisper quiet!
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9085400
Just now, TubsAlwaysWins said:
But poo brown
Be quiet fans are pretty good, linus made a PC with some of them and it was very quiet.
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9085407
54 minutes ago, W-L said:
For black fans some good units would be the fractal design venturi's or scythe gentle typhoons.
I have three Venturi HP-12 PWM fans. They have 'dick dick dick" motor noise under 1000rpm. While the HF-12 is good no problem. Don't know if I get some faulty ones.
Meanwhile, Gentle Typhoon is THE fan to have for radiator. Noticeably better than Noctua NF-F12. Have four of them in my main rig.
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9085714
Not sure might be faulty are you running the fans via PWM control, I had a bunch that a buddy got and installed them for him and they were close to dead silent under about 700-800 RPM.
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9086031
What are your specs and which fans are too loud? What speed are you running your fans at? Have you tried lowering them?
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9091724
I have a Corsair C70 case and I need 2 airflow and 2 static pressure fans 120mm, thinking of getting these hybrid fans for both air movement types. I was wondering if there was a cheaper or better option than this. Thanks.
(Fractal Design Dynamic GP-12)
https://www.amazon.com/gp/product/B00XO33SI6/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9094408
I would try posting this as a new topic instead of on this one. Also from what I hear Noctua NF-F12's are more static pressure but get the job done for both. They are bust very expensive
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9094768
My specs are i5-6600K, EVGA Z170 FTW, and a R9 270X in a H440. Im running my fans at stock and I can't lower them because nothing will let me
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9094781
Are you referring to the stock case fans? What headers are the fans plugged into?
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9095793
2 hours ago, TubsAlwaysWins said:
My motherboard headers
Which headers? They should be labelled. Have you adjusted their speeds in the bios?
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9101798
hahahaa thats a......nice way of putting it
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9102559
1 hour ago, TubsAlwaysWins said:
No because I don't think EVGA has a option for that. I also havent checked tho
They are labelled on the motherboard.
Try to enter the motherboard settings during startup.
https://linustechtips.com/topic/711900-what-fans-to-get/#findComment-9102731
