Going "Neutral" in shooters
Rhinnw
If you have 5 kills and 2 deaths, you go positive
If you have 2 kills and 5 deaths, you go negative
but if you have 5 kills and 5 deaths, do you call it neutral or just positive?
I call it neutral, but this post really belongs in Gaming sections. If you think about it, even if you go "negative" your KDR is still a positive number.
Welcome to Maryland.
We have crabs.
Neutral. Your K/D is 5/5, which is 0, which is not a positive or negative number.
EDIT: To clarify, to all intents and purposes your K/D is zero. I know 5/5 isn't 0.
Other systems I've built:
5/5=1 though? This is the discussion I'm having with someone lol, I think it's called neutral though
No matter what if you divide a positive number by any positive number the result will be positive, even if you are going "negative". So neutral is when you are neither below or above one.
We have crabs.
I know, I edited my original post. To all intents and purposes, your K/D is zero because there is no difference (zero difference) between your kills and your deaths. You have died one time for each of your kills, and you have killed one time for each of your deaths. It goes both ways.
Read my edit. I know 5/5 doesn't actually = 0 lol :P
Oh my bad I quoted it before the edit lol.
We have crabs.
its 5:5 and thats the same as 1:1, its neutral
Builds:
Wait, what if while your KDR (kills divided by deaths) is based on division, the way you are going (positive, negative, neutral) is based on subtraction? Than you actually ARE negative when you have more deaths than kills, and you ARE neutral when you have the same? Mind BLOWN.
We have crabs.
Are we talking strictly in a numerical sense? Or are we talking impact on a match? K:D ratio's are less important in some shooters (Overwatch being an example) as it has less to do with how many kills you have, or how often you die, and more to do with the impact of your kills/deaths. If you have say, 5 kills, 7 deaths, but one of those 5 kills were a game changing strategic pick, it did far more for the match than say, someone with a decent K:D ratio that picked off random people.
If we are talking strictly in a numerical sense, 5 kills and 5 deaths is neutral, you broke even. Think of it as a +5 and -5 value. Using PEMDAS, you start with addition, then subtraction. So base is 0, +5 makes it 5, then -5 makes it 0. In this sense, Kill's represent an addition value, deaths represent a subtraction value.
My (incomplete) memory overclocking guide:
Does memory speed impact gaming performance? Click here to find out!
On 1/2/2017 at 9:32 PM, MageTank said:
Sometimes, we all need a little inspiration.
I have always considered being above 1 a positive K/D and under a negative. If someone just has a 5K and 5D I call it 1 K/D. Seems I'm in the minority here but I've heard it called a 1 K/D by many people or a "standard score." I've heard standard score because when you first join the match you have 0K and 0D. If you later have 5K and 5D then its a standard score. Considering everyone else I suppose this answer isn't the best but it's what I've always heard it called.
Except if you have 0 kills and 0 deaths you don't have a kdr of 1. Your KDR is undefined because any number, even 0, divided by 0 is undefined.
If you divide 0 by 0, you have an infinite number of values that can be used. Even infinity itself can be used to get 0. But if you divide any other number by 0, then nothing works.
While intuition may say that's true, Mathematical theory states that 0/0 is nondefined for various reasons such as breaking arithmetic.
KDR and going Positive/Negative aren't 100% the same thing. If you go positive, you've had more kills than deaths, negative is vise versa, and if you have the same number of kills and deaths, it's often called EVEN in my experience. It's just the simple equation of Kills - Deaths = Pos/Neg/Even
KDR is just how many kills you average per death, and does have a tight relation to going positive or not.
Most games now consider 0 kills and 0 (or any number) deaths as a KDR of 0, because the number being divided is 0. Can't have a KDR higher than 0 if you don't get a kill.
It doesn't work the other way around though, because the game goes on the assumption that the character would eventually die (if in game, just due to a longer game, if applying the logic of real life, old age), and thus substitutes the 0 for a 1 for D.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
Indeed, it still cannot be determined as you can plug in any value and get the same answer. There isn't one number that brings it together compared to something like 15/3.
Dont think about your KD ratio or end match stats, focus your mindset on mastering the game, helping your team even if you gonna die a lot and getting better at it. I used to care only about stats when i played Battlefield and in the end became a liability to my team by avoding hard to get objectives.
