Hey guys,
I'm stuggling to make a batch file that uses RCMD to start another Batch file on a network PC.
Please review and let me know your thoughts. I've had to *** out folders to conceal my employer (sorry!)
@echo off
echo This file must be placed on your Jumpbox desktop.
set /p ID="Enter ID:"
C:\*****\pstools\rcmd \\%ID%-bos1 cmd
start "" "c:\Program Files (x86)\*****\SiteLink\Bin\MsgManCallHostNow.bat"
pause
Thanks in advance.
Brad
https://linustechtips.com/topic/710289-help-please/
Shouldn't this be "cmd.exe" in the end? (not sure if it makes a difference).
Why are you using "start"? If you want to run a batch file just traverse to it as follows:
and it will run. Only use "start" if you want to run stuff asynchronously. Is that what you're trying to do?
https://linustechtips.com/topic/710289-help-please/#findComment-9071113
Thanks Darkangel,
It doesn't matter whether you specify cmd's file extension.
I've removed start and it makes no difference.
When I run the batch file, it connects to the remote machine via RCMD and then does nothing.
https://linustechtips.com/topic/710289-help-please/#findComment-9071725
1 minute ago, icey said:
Thanks Darkangel,
How are you sure that it is doing nothing vs. just not returning an output to you?
In the batch file, can you have it create a file or dump output to file just to verify whether or not something's happening on the remote machine?
https://linustechtips.com/topic/710289-help-please/#findComment-9071738
I have no idea, I do like the sound of it though :D
https://linustechtips.com/topic/710289-help-please/#findComment-9071753
5 minutes ago, icey said:
It's definitely not executing the batch file I can confirm
Okay, let's backtrack a little bit.
Can you do any thing on the remote machine?
Let's try to do something like "dir > output.txt" in C:\
then verify that output.txt was created in C:\ (you need to be admin to do this).
https://linustechtips.com/topic/710289-help-please/#findComment-9071855
Yes I have full privs - I'm able to do anything in the cmd prompt once the batch file connects to the remote machine
https://linustechtips.com/topic/710289-help-please/#findComment-9071863
Okay, can you run OTHER batch files? Create a simple one and test.
Also can you actually execute the following line manually once you are connected to the remote machine?
If so, what is the output?
https://linustechtips.com/topic/710289-help-please/#findComment-9071875
It works as intended if I paste " c:\Program Files (x86)\*****\SiteLink\Bin\MsgManCallHostNow.bat"  after the cmd prompt opens
I can also run any batch file, no a question of privs being network admin
https://linustechtips.com/topic/710289-help-please/#findComment-9072022
Thanks for all your help Darkangel,
I figured out the batch file I was trying to run was simply calling another batch file. I re-wrote it to look like this which works perfectly :)
@echo off
set /p ID="Enter Site ID: "
C:\*****\pstools\rcmd \\%ID%-bos1 call "c:\Program Files (x86)\*******\SiteLink\Bin\SSMsgManCtrl.exe" CONTACTHOST
sleep 3
echo Download Complete!
pause
https://linustechtips.com/topic/710289-help-please/#findComment-9098064
@echo off
sleep 3
pause
Glad it worked out! Thanks for reporting back so others can utilize your findings!
https://linustechtips.com/topic/710289-help-please/#findComment-9098992
