quiet air CPU cooler
Go to solution Solved by Guest,
What is your budget? Noctua NH D15
Just now, Morsher said:
Is that quiet?
Very quiet.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/709854-quiet-air-cpu-cooler/#findComment-9063092
1 minute ago, Morsher said:
Will Noctua NH D15 fit in Fractal Designe R5? And also will it not mess with RAM?
6 minutes ago, Morsher said:
Aight. Let's say my budget is ~ 80 bucks. I want silent and cold cooler. Still Noctua?
Noctua might get in the way of rams, depend on which one
If not Dark Rock Pro. See if Noctua fits your budget
https://linustechtips.com/topic/709854-quiet-air-cpu-cooler/#findComment-9063141
7 minutes ago, Morsher said:
What do you mean? Like im JB.
Will it not mess with Kingston Hyperx Fury? You wanted specific RAM?
It might not fit
Size of your RAM: Height 1.291” (32.80mm) w/heatsink
NH-D15
Though dual fan would provide better cooling
Same goes to Dark Rock Pro 3.
So uhm try and remove the heatspreader?
https://linustechtips.com/topic/709854-quiet-air-cpu-cooler/#findComment-9063167
29 minutes ago, Morsher said:
I will oc my CPU to 4.6 ghz at least so i want it to be quiet on that frequency.
You should check out any of these 3 coolers:
Noctua DH-15 (best one here, but ugly af)
Cryorig R1 Ultimate (or R1 universal if you have taller RAM)
Be Quiet! Dark Rock Pro 3 (Be Quiet! is all about staying quiet, so you can expect good things here)
I also feel like its worth mentioning the Cooler Master V8 GTS and/or the MasterAir Maker8 (although this one is quite pricey) if you are interested in a black/red aesthetic. they're massive, have great cooling, and look pretty cool. not sure about acoustics though. Any of the first 3 options would be ideal for your request of a decent OC and minimal noise. Its worth noting that all of them will require very low profile RAM (something like Corsair Vengeance LPX) or come with adjustable fan heights to compensate for slightly taller RAM. If you want tall RAM like Dominators, you may consider the R1 Universal which offers slightly less cooling than the R1 Ultimate (slimmer fan on the front) but does not overhang the RAM slots as a result.
If your only goal is performance+noise/cost, then the DH-15 is what you should get, but if you care about aesthetics and are willing to take minimal hits to the first 2 points, then either the R1 Ultimate or Dark Rock Pro 3 would be more ideal for you.
https://linustechtips.com/topic/709854-quiet-air-cpu-cooler/#findComment-9063179
1 hour ago, deXxterlab97 said:
It might not fit
Fury ram fits just fine. The fans can be mounted higher up or lower depending on preference.
I got some beautiful low profile RAM guys.
I think it fits with NH D15.
https://www.computeruniverse.ru/products/90566662/crucial-16gb-ddr4-pc2133-cl15-kit.asp
This is standard profile ram.
https://linustechtips.com/topic/709854-quiet-air-cpu-cooler/#findComment-9063419
6 hours ago, Morsher said:
I don't think so. Lower than that i couldn't find.
The ram you're probably used to seeing with heatsinks are usually a standard height pcb with an additional heatsink resulting in high profile ram.
https://linustechtips.com/topic/709854-quiet-air-cpu-cooler/#findComment-9067044
