Will a fan hub allow me to run fans below 60%?
3 minutes ago, KenniiKalonji said:So i have this case but removed the fan hub because... well it was ugly. My motherboard won't run the case fans below 60%. I want to set a custom fan curve with the fans way below 60%. Will this be possible if i put the fan hub back on and connect the case fans to it? the fans are all 3pin fans. i'm trying to get my machine to be a bit quieter... especially considering my cpu isn't even topping 35 degrees. My case is the Phanteks evolv entoo tempered glass edition. Motherboard is an asus ROG x99, it's my first build so I am not an expert...yet.
Sorry if I am posting this in the wrong place, but i just created this account and don't know the rules here yet. I also just built my first pc and am having this question. any response will be appreciated.
Welcome to the Forums!
A fan hub will only expand the number of connections and not change the speed of the fans as the controller is responsible for that. It sounds like your fans are your limiting factor not being able to start at less than 60%, but just to make sure check your BIOS to ensure the headers are set up as DC voltage control for 3 pin fans and PWM for 4 pins respectively.
