Can my Power Supply Run the 1050?
Solved by faziten,
it will probably work just fine. Would i recommend it? No. Why? Even if it works we can't assure for HOW LONG. Maybe weeks? Years? Hours? One boot and Poof*?
Once you go out of spec there is little to hold to but luck itself. Want to test your luck? Go ahead.
Featured Topics
Spencer The Mid ·
Posted in Hobby Electronics0 -
Eurimeee ·
Posted in Troubleshooting1 -
2
