Case fan PROBS
Solved by W-L,
7 minutes ago, CHILDISH_K1LL3R said:I'm making my first ever build (cuz i'm a noob) and I'm not sure what case fan I should get. Going to maybe get Coolermaster Mastercase Pro 5, I don't mind if it is not quiet
It just depends on what you like really but for somewhat decent fans the Corsair dual packs aren't bad, if you want silent options, some Noctua's, Fractal Design Venturi's or Gentle Typhoons are good options.
