6700k 4.6ghz @ 1.34v Normal Temps?
Solved by Thony,
Well according to Jay and Paul 1.35 is maximum they would ever go for 24/7 use.
70 sounds fine and if higher rpm on cooler dont cut it then u might want to go down to 4.5Ghz if you want lower temps.
gentlemanspot ·
Posted in Console Gaming0 -
1
Idkwhattodowithmylife ·
Posted in Graphics Cards5 -
4eyeguy ·
Posted in New Builds and Planning4 -
Gin N Rum 5454 ·
Posted in Programs, Apps and Websites3 -
