This should help you get started:
Keep in mind not all CPU's overclock as well as others, so you may need to dial down the overclock or up the voltage if you PC crashes while testing it.
idle doesn't matter too much. you need to stress it. RealBench from Asus is a good stresser, as is the Adia64 stresser.
A question for the peanut gallery: should a guy concern himself with individual core temps, or package temps? i've focused more on the latter but i see there are some instances of a over-temp log on individual cores while performing stress testing.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Be concerned with all of them: if any part of my CPU is going above 90 when I'm stress testing (my own personal limit, everyone is comfortable with different temps), I tone down the voltage.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
sounds good.
System specs:
On 12/13/2016 at 5:35 PM, Divyank said:
I overclocked my i5 4690 k at 4.48 GHz (102 x 44) with voltage 1.248 and ram at 1899.5 MHz using Cooler master hyper 212x cpu cooler is it safe. I can go faster or have to reduce the voltage?
What is your temperature on the CPU at full load? You need to be testing the temperatures any time there's an adjustment being made where energy consumption is increasing, particularly on the voltage side.
