1080p on 1440p monitor?
Abhinavp
How will games look if change the settings to 1080p on a 1440p monitor?
Not good. 1440p Is a multiple of 720, not 1080. 4k is a multiple of 1080. So it will look better scaled to 720.
Computers r fun
It would probably look bad because the 1080p resolution would upscale to 1440p... Even if you set your monitor to 1080p, it would not be running at its native resolution.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
The display would, more than likely, stretch the image to fit the screen. Because 1080p won't fit correctly, the image will look bad.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
