Whats this build for? You could easily downgrade the 1070 to something else and save a few bucks..
https://linustechtips.com/topic/703102-pc-build-for-check/#findComment-8986740
not bad, I5 will bottleneck but its good, if you can wait to mid january the Kabylake like of CPUs should be out, and maybe the 490 even, and maybe you could get some more preformance for your cash, but if you dont want to wait this is a pretty good build
Builds:
https://linustechtips.com/topic/703102-pc-build-for-check/#findComment-8986772
I'd get a different PSU. You can get a 650W 80+ gold PSU for the same price ( Corsair RM650X). No reason to get such a low Wattage PSU, plus the Corsair is fully modular.
There are many other PSUs with 650-750W and 80+ gold ratings out there.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/703102-pc-build-for-check/#findComment-8986774
I wouldn't hold my breath for Kaby Lake. Incremental speed bump at best. if nothing else, wait til Kaby Lake launches and snarf up all the used 6700k's for cheap.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/703102-pc-build-for-check/#findComment-8986812
could be better value, the unlocked I3 is interesting and the I5 7500 will be better then the I5 6500 and probably about the same price
Builds:
https://linustechtips.com/topic/703102-pc-build-for-check/#findComment-8986822
What monitor will you use with the computer? If it's a regular 1080p 60Hz screen you might as well downgrade to a GTX 1060 instead (unless you plan to get a 1440p monitor in the near future).
I would probably spend a little extra and get a 6600k and an OC motherboard (Z170 chipset) in case I'd turn to overclocking in the future (note that when that's the case you'll need better cooling and a better PSU, but there's no need to invest in that until the moment arrives and you want to start overclocking). It's a bit more expensive, but a worthwile investment.
Asus X99-A w/ BIOS 3402 | Intel i7 5820k OC @4.4GHz 1.28V w/ Noctua NH-U14S | 16GB Corsair Vengeance DDR4 OC @2666MHz 12-14-14-28 | Asus Geforce GTX970 STRIX OC | EVGA 750 G2 750W | Samsung 850 Evo 1 TB | Windows 10 64-bit | Be-Quiet Silent Base 800 w/ Silent Wings | 2x Dell U2414H OC @72Hz w/ Display Port
Don't forget to invest in an Intel Tuning Plan if you're going to overvolt your K/X CPU
https://linustechtips.com/topic/703102-pc-build-for-check/#findComment-8986823
Is for gaming.
I will wait
https://linustechtips.com/topic/703102-pc-build-for-check/#findComment-8990180
actually it was 550W, after that someone told to downgrade the psu.
I think I will just replace it to 550W
https://linustechtips.com/topic/703102-pc-build-for-check/#findComment-8990192
my monitor is 1080p 144Hz
https://linustechtips.com/topic/703102-pc-build-for-check/#findComment-8990198
Ahh, then a 1070 will do great
https://linustechtips.com/topic/703102-pc-build-for-check/#findComment-8990715
