Cable for 240hz
Solved by Glenwing,
14 minutes ago, jojocool111 said:I have a gt 780ti. That has displayport, im pretty sure. Im not good with displays, so will it work with a 780ti at 240hz. Or is that dp too old?
The GTX 780 Ti supports DisplayPort 1.2, which will be capable of 1080p 240 Hz. The HDMI port on it is version 1.4, which will be limited to 1080p 144 Hz or lower.
