I'm 14 and am about to buy my PC parts, I have saved for years and have about £1400 shall I spend it all or save a bit?
I ask this because my dad isn't too happy with the idea of me spending this amount of money
CPU: 4670K / Cooler: H100i / RAM: 4x4GB Corsair Vengence Pro 1866MHz / Motherboard: MSI Z87-GD65 / GPU: MSI TF 780 Gaming Edition / Case: Corsair Vengence C70 / Storage: 250GB Samsung Evo & 2TB Seagate Barracuda / PSU: EVGA SuperNova NEX750G
https://linustechtips.com/topic/69965-how-much-shall-i-spend/
I would spend about max. 1200 but really know what you are going to buy!
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/69965-how-much-shall-i-spend/#findComment-958645
Well it's ultimately up to you. I spent ~2000£ on my first build which is my current one (built 2 years ago..). If you have the passion for the "hobby" if you will, then go ahead and get a beast machine, if you are not but want to play games on PC get a budget build.
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/69965-how-much-shall-i-spend/#findComment-958658
I am just about to do the same thing, and i am the same age. I have saved up just about enough
This is what i am going to get, maybe you could get something similar to this
http://uk.pcpartpicker.com/p/1T7HP
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/69965-how-much-shall-i-spend/#findComment-958679
Consider an aftermarket cooler and get your OC on :D
https://linustechtips.com/topic/69965-how-much-shall-i-spend/#findComment-958698
I don't plan on OC straight away, i might wait until i notice a performance decrease. Then i will install a better cooler and OC.
Thanks
https://linustechtips.com/topic/69965-how-much-shall-i-spend/#findComment-958710
spend all of the money ever
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/69965-how-much-shall-i-spend/#findComment-958722
Save somewhere between 100-400, save it for a rainy day or slowly save money or put it in an interest account.
In 2 years or so you could do a nice upgrade!
I'm the one who overclocks.
CPU: i5 2500k w/CM Cooler Master Hyper 212 EVO OC'd@4.2GHz RAM: Corsair Vengeance 8GB  MOBO: Intel Burrage DP67BG GPU: MSI GTX770 Twin Frozr 2GB HDD: 2x Seagate 2TB Barracuda PSU: Gigabyte ODIN 550W
https://linustechtips.com/topic/69965-how-much-shall-i-spend/#findComment-958820
800 to 1000 is the sweet spot...
Sent from my GSmart Aku A1 using Tapatalk
Case: Xigmatek Alfar (Black) | CPU: Intel Core i5 4460 @3.2GHz | MoBo: Gigabyte GA-Z87-D3HP | RAM: Crucial Ballistix Sport 8GB 1600MHz | GFX: Gigabyte GTX 660Ti 2GB
Cooler: beQuiet! Shadow Rock | SSD: Samsung 840 EVO 120GB | HDD: Seagate 'Barracuda' 2TB| OS: Windows 8.1 PRO (64-bit) | PSU: Zalman ZM600-GT 600W 80+ Bronze
 Screen: ASUS VS228 | Mouse: Razer Naga Molten | Headphones: Qpad QH-85 | Keyboard: Razer Blackwidow 2013 w/ Cherry MX Blue
https://linustechtips.com/topic/69965-how-much-shall-i-spend/#findComment-958829
You can get a pretty good rig for 500 pounds in the US, but I am not sure how much more expensive parts are in the UK.
Athlon X4 760K | MSI A88X-G43 | 8GB G.Skill Ripjaws 1333Mhz | MSI R7 260X 2GB | Corsair 300R | Corsair CX430 | 640GB HDD | Windows 7 64-bit
HP W2071d 20" 900p TN | Stock Dell K/B | Microsoft Comfort Optical Mouse 3000 + SteelSeries Qck Portal 2 Ed. | Grado SR80i + cheap 2.0 speakers
https://linustechtips.com/topic/69965-how-much-shall-i-spend/#findComment-958831
