Background sound problem...
Go to solution Solved by Dackzy,
7 hours ago, TOOMAAS said:
Ive got my mic on an arm and its hanging to the left of my desk.
it needs to be in front of you keyboard. You mic picks up everything from the sides and from the front, but not the back, so in theory it should help to have the mic in front of the keyboard.
Hello,
I have a question...
When I'm gaming and talking to my friends on discord, they can hear keyboard very loud.
I tried to set the sensitivity of my microphone lower. but then my voice is too silent.
I'm thinking about buying O-rings for my keyboard.
But if there is another way to minimalize the background sound, I will try that.
Does someone know another way?
I've got a corsair k70 lux keyboard and a rode nt-usb microphone.
Thanks a lot and sorry for my bad english.....
https://linustechtips.com/topic/699259-background-sound-problem/
How is the mic setup? Do you have it on your desk or do you have it on a boomarm?
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/699259-background-sound-problem/#findComment-8943584
Use push to talk. Also, if there's a setting to make it unidirectional, do that too.
You seriously don't want to be this guy
https://linustechtips.com/topic/699259-background-sound-problem/#findComment-8943618
I like where your going.
Its probably just the mic. I have seen headsets with awesome mics, and some with mics that pick up background noise better than your voice.
Computers r fun
https://linustechtips.com/topic/699259-background-sound-problem/#findComment-8943621
the placement of the mic and the pickup pattern are both very important. His mic has a polar pattern, which is good here.
This leads me to belive that he has his mic standing on his desk with that little tripod, that he got with his mic.
https://linustechtips.com/topic/699259-background-sound-problem/#findComment-8943647
https://linustechtips.com/topic/699259-background-sound-problem/#findComment-8948176
