Just now, rphawks said:
Is that sarcastic... or legitimate?
sorry, legitimate, its only a small inconvenience to have to go through all my settings again, but that's totally fine since i do that anyway with every new device i get. i love optimizing things.
6 minutes ago, EdgieHippie said:
so, random sidenote:
with reguards to this video:
3:58, im confused. if i get this: https://cablemod.com/product/cablemod-widebeam-magnetic-rgb-led-strip-60cm/ where do i get the cable he is saying i do need to use. is that in here? https://cablemod.com/product/cablemod-widebeam-magnetic-rgb-led-kit-60cm/ so i would have to get one kit and one strip? except on the single strip one it says i dont need the kit if i have asus aura controlers, which i do. so do i then just plug the rgb strip straight into the motherboard?
derp nvm i can buy single strips, and dont need a kit. it says
Here’s what you get inside the package:
  • 1 x WideBeam Magnetic RGB LED Strip
  • 1 x ASUS® Compatibility Adapter
  • 2 x 4-pin Connectors
Judging by this:
You can use the 1st kit if you have an AURA header on your motherboard. If not, you'll need the second kit and the 1st would be an extension from the second.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
4 hours ago, EdgieHippie said:
im sure going to this: https://www.amazon.com/dp/B0153P9SEK/ref=psdc_1292116011_t2_B00V01C6M8
would make a difference: Read Speed: 2500MB/s, Write Speed: 1200MB/s
but it also costs way more.
also, these benchmarks show that m.2 is faster:
only by a few seconds, but of the two im comparing, the m.2 is only $20 more than the sata, also that would leave one more sata spot open for hdd's later, although that probably wont matter much xD
Dont cheap out on m.2. Thpse as sinthetic benchmarks. Sinthetic and real world have a differnece. In the real world, there will be no application that uses 1200mb speeds. Sinthetics jut tests the capability, but in the real world, those speeds jut dont happen
3 hours ago, EdgieHippie said:
i also just thought of, if i were to go with a 2.5 inch sata ssd, would i need something to make it fit in the 3.5" bays?
Yes, unless you drill holes
1 hour ago, EdgieHippie said:
" You get a watermark in the bottom right hand corner of the screen and you can't utilise Microsoft account services such as syncing settings between devices. Other than that, it pretty much works as expected. " fantastic
Its te same, syncing works
Some mb have rgb headers, others dont. color rgb connects either to molex or oter connectors
Widebeam is asus proprietary
Actually I think it's CableMod proprietary.
Skyggeis Specs:
a slight side note: i heard a rumor that the warrenty for the corsair h100i v2 includes that they would replace any and all parts damaged if it were to leak, but i cant seem to find such information anywhere. can anyone help me figure this out? cause i realize that them leaking is quite rare, but im still worried about it never the less. unless if yall have any other AIO's youd suggest.
  • Hydro Series™ products have a 5 year warranty
Some say it covers it. I wouldn't know, but since their PSU covers all parts, the cooler probably does.
Skyggeis Specs:
Yes, sorry I meant asus aura
If it kills anythung as well, and there is reasonable proof, (cooler leakin oj gpu) corsair eill replace all parts destroyed by the leakage
9 minutes ago, EdgieHippie said:
yey! cause then im not too worried. if it leaks itll only be a minor inconvienence of time spent not using the computer to replace the parts vs if i were to have to buy all new parts
Yeah, theyll replace anything that is broken because of their aio. With reasonable proof of course
Yeah. No like... Oh it exploded and I was cooling with kerosene.
Skyggeis Specs:
You have to buy the afapter if you dot have a mobo with asus aura
Um...
"1 x ASUS® Compatibility Adapter"
clearly not... xD
Skyggeis Specs:
42 minutes ago, rphawks said:
Um...
clearly not... xD
The adapter for aura comes with the light strip, but the adapter kit for molex and whatever needs to be bought otherwise I believe, but dot quote me on it.
Since he foes have aura, he wont need the kit
43 minutes ago, EdgieHippie said:
i do have asus aura tho so yey :D
What mobo did you pick
Yes. That is true.
For the Mobo he has the ASUS X99-E.
Skyggeis Specs:
15 minutes ago, rphawks said:
Yes. That is true.
Not activating Windows also disables DirectX. Literally required for almost every program. If hes spending that much on a rig he needs full windows.
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
Really. Anyway to see that? I can run everything...
Skyggeis Specs:
thank god you told me that then xD
you can run unlicensed windows, (8.1 or so, not 10), and then upgrade to 10, that will change an unlicnesed code into licensed
Run Firestrike
AXIOM
I'll do it tonight. I've run things like Ungine Heaven before.
Skyggeis Specs:
12 hours ago, faziten said:
Are you sure those ram sticks are compatible with that particular motherboard?.
X99 is not friendly with every stick out there... even a single number in the model makes the difference between a happy boot and error 53.
i figured they would be. just to be sure, this is what ive got: https://pcpartpicker.com/list/MD4nyf
i already ordered the parts so i hope they are compatible. they are both ddr4 quad channel. it supports up to 128, im only getting 26 rn and will go to 32 if i need to.and its only got a cas latency of 10 giving it the fastest response time available for the price.
