3 hours ago, rphawks said:
Don't go with that power supply. GS line is pretty old.
hows this look then? https://pcpartpicker.com/list/ not including my 512gb m.2 ssd. ill then get hdd's and a 4k monitor later when i can afford it
lol fail. i meant hows this: https://pcpartpicker.com/list/MD4nyf
get the hx 750.
its more than enough, and also futureproofing slightly.
dont get m.2, just get sata. m.2 isnt worth it
get the h110i(v2) dont get the 100, its not worth, trust me. else, just get an air cooler.
2 minutes ago, Bajantechnician said:
get the hx 750.
whats the difference between the rmx and hx beside the rmx is fully modular, and the hx is semi
also, why is m.2 worth it? isnt it significanty faster for about the same price?
or would this be better? https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=hyperx predator its 20 dollars less than the m.2 i chose
thats basicly it, hx and rmx. sorry, i made a mistake, get the rmx750, or ax 750. ax is top of the like quality corsair. thats what i have, ax1500i. m.2 is not worth it. basicly the same speeds, for a lot more money. no,
this: http://www.newegg.com/Product/Product.aspx?Item=9SIAAZU4NC1136&ignorebbr=1 is the m.2 i was thinking of
get good ssds, (samsung,crucial, kingston) and wd hdds
5 minutes ago, Bajantechnician said:
dont get m.2. I have it. Its not worth it.
so something like this? https://pcpartpicker.com/product/88tCmG/crucial-internal-hard-drive-ct512m4ssd2 aso, does the cable for that come with the psu?
vs this: http://www.newegg.com/Product/Product.aspx?Item=9SIAAZU4NC1136&ignorebbr=1
yes
6 minutes ago, EdgieHippie said:
the traditional ssd: Sequential Read 500 MB/s Sequential Write, 260 MB/s (128k Transfer)
the m.2 ssd: Max Sequential Read, Up to 1775 MBps, Max Sequential Write, Up to 560 MBps
doesnt matter, it looks good on paper, but it doesnt make a difference
for $25 more and 50% faster i dont see why it wouldnt be. maybe you just chose a bad m.2 :P
i have a top of the line 512 gb samsunng 850 pro m.2
4 minutes ago, Bajantechnician said:
yes
im sure going to this: https://www.amazon.com/dp/B0153P9SEK/ref=psdc_1292116011_t2_B00V01C6M8
would make a difference: Read Speed: 2500MB/s, Write Speed: 1200MB/s
but it also costs way more.
also, these benchmarks show that m.2 is faster:
only by a few seconds, but of the two im comparing, the m.2 is only $20 more than the sata, also that would leave one more sata spot open for hdd's later, although that probably wont matter much xD
also @Bajantechnician i really do appreciate you sticking with me on the 1070sli vs 1080 discussion, however, the 1070sli costs more, and i can barely afford the 1080 xD the current config is up at 1979.37, plus i wanna get some rgb strips. im gonna run this system for like 6-8 years until i just cant anymore, and will completely milk it for all its got. my current system ive had for 5 years, and probably wont last the rest of this year.
Do you have to buy Windows 10? I use it without a license.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
Just now, EdgieHippie said:
im aware that thats possible, but i wonder what the drawbacks are. do you know?
Not really much. The only drawback I have is not being able to change the image of the login screen, but the Windows ones are so nice anyways it doesn't bother me.
It also locks you out of the customization tab of settings, but there's an alternate way to set your wallpaper. You can just right click an image and click "Set image as desktop background".
Skyggeis Specs:
Oh and there's a small watermark around 1" by 1.5" in the bottom right corner of your desktop that says "upgrade to Windows". I deal with it though. It's not worth paying $80-90 to get custom login screens and a small watermark removed.
Skyggeis Specs:
so there are no truely bad things about the unactivated version? if not, then thank you a ton!
so, random sidenote:
with reguards to this video:
3:58, im confused. if i get this: https://cablemod.com/product/cablemod-widebeam-magnetic-rgb-led-strip-60cm/ where do i get the cable he is saying i do need to use. is that in here? https://cablemod.com/product/cablemod-widebeam-magnetic-rgb-led-kit-60cm/ so i would have to get one kit and one strip? except on the single strip one it says i dont need the kit if i have asus aura controlers, which i do. so do i then just plug the rgb strip straight into the motherboard?
" You get a watermark in the bottom right hand corner of the screen and you can't utilise Microsoft account services such as syncing settings between devices. Other than that, it pretty much works as expected. " fantastic
Is that sarcastic... or legitimate?
Skyggeis Specs:
