this is what ive got so far: https://pcpartpicker.com/list/GPTWzM
note it says there are incompatabiities, thats just that i might need to update the bios, however: https://www.youtube.com/watch?v=HM0Ipk6i8tA&ab_channel=TechDeals according to him i wont have to worry about that.
i need to choose a powersupply and a case. also, theres the matter of i plan on adding HDD's later, and the small posibility of adding anouther gtx1080 later for sli, and idk if id be ok with the cable that come with, or if i should go ahead and get some cablemod cables instead. any and all suggestions apprecieted! i need to have it done by the end of the night tho to get cyber monday deals
https://linustechtips.com/topic/698902-first-time-build-plox-help/
You don't have a CPU cooler, PSU, or case
All PSUs come with cables for everything and at least 2 8-pin PCIe cables.
CPU cooler: You have to decide air or liquid cooling and give us a budget. We'll help from there.
PSU: Need to choose all your other parts first and if you plan to upgrade in the future + budget. PSU comes down to personal brand sometimes in the end. DO NOT buy an unreliable PSU. Check out the PSU Tier list.
Case: Color scheme, budget, and aesthetics. This is more of a "you choose, we approve" category.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
P.S. Please use proper sentences and capitalize. Just... please.
Skyggeis Specs:
Sorry, I'm thinking an all in one water cooler so I don't have to mess with pipes and such.
Color scheme: all the colors xD
budget, ideally under 1500, but max of 2000 if necessary
1. Why AIO water?
2. All the colors is quite unspecific.
3. Is that for the whole PC?
Skyggeis Specs:
Just now, rphawks said:
1. Why AIO water?
because i dont want to mess with pipes, and as long as its of reliable quality i figured it would be better than air, especially for overclocking.
yes, yes it is, meaning i dont care about color scheme
and yes for the whole pc
1. Er... water isn't always better than air. And AIOs have pipes. You risk a leak too with AIOs.
2. You should choose a color scheme. It helps us narrow down stuff. There are a lot of "good" products out there.
3. What about mouse, keyboard, and monitors?
Skyggeis Specs:
Well, if you can find a good air cooler, id be cool with that; and i have all my peripherals already. Well, my ram is blue, and i was thinking id make the controlable LED's in the GPU green, and the MOBO red, so maybe any of the colors I dont have yet, such as yellow, or purple. Rainbow Rig xD
You have a good monitor? It'd be a shame to run a 1080 at 1080p. Also... why do you need a 6800K? Do you video edit and stuff?
Skyggeis Specs:
yes, and yes. as ive said before i dont have time to discuss those parts. i need to get this built, and the links sent to my brother so he can order them by 9pm, 3 hours away for me
Then I can't help. Don't hurry. What's your monitor?
Skyggeis Specs:
Also, you might have to BIOS update with that board. Meaning you'll need a native X99 CPU for that board. Or get a different board.
Skyggeis Specs:
i have already adressed that. plase read before posting. normally i wouldnt mind correcting you but this is a time sensative project
I read it. You can update via USB. Do that then. I didn't bother to watch the video. This is what I would recommend:
PCPartPicker part list: https://pcpartpicker.com/list/bttJgL
Price breakdown by merchant: https://pcpartpicker.com/list/bttJgL/by_merchant/
CPU: Intel Core i7-6800K 3.4GHz 6-Core Processor  ($379.99 @ Newegg)
CPU Cooler: CRYORIG H5 Universal 65.0 CFM CPU Cooler  ($46.88 @ OutletPC)
Motherboard: Asus X99-A II ATX LGA2011-3 Motherboard  ($204.99 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($93.99 @ Jet)
Storage: Crucial MX300 525GB 2.5" Solid State Drive  ($99.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: Asus GeForce GTX 1080 8GB STRIX Video Card  ($678.99 @ SuperBiiz)
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Corsair RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Newegg)
Total: $1678.70
MX300 isn't the fastest, but you wanted it. Replaced 212X Turbo with H5 Universal (you can buy ultimate if you don't mind blocking a ram slot). You actually might not need to BIOS update. Added a 1TB HDD, but you might need more for video storage. This system is probably totally WAYYYYYY overkill for what you do, but whatever. And please capitalize properly. That is all. *sigh*
Skyggeis Specs:
You'd better use this rig to it's full potential. Judging by your grammar and capitalization though... You were lucky I took you even somewhat seriously tbh.
Skyggeis Specs:
trust me, this is not overkill at all. I will be redering full 3-4 hour highly edited movies, making full albums,  and countless other things. in fact, id say its modest for my use. and there is no reason for you to be rude rn. i dont have time for capitalization, or for your attitude.
My attitude should be expected. You do have time.
Skyggeis Specs:
no i dont if i wanna save via cyber monday deals
You should have bought on Black Friday. All the good deals are gone and CPU and GPU prices have gone back up 50%.
Skyggeis Specs:
i am aware of this, however i was going to wait anouther year before doing this, then my work computer took a crap and so i have to do it now. i have no other choice. i dont as ive said i dont have ime to be explaing all this. im done replaying to you, your wasting my time. ive only got an hour left to figure this out. i appreciate your suggestion tho, and will consider that.
