Cable Lenght and Lag?
Litow14
I was wondering if or how much lag would be introduced based one the length of a mouse, keyboard, hdmi cable. I was working on my new studio and thought is having the computer out side the room. The room is 15x9 so the most a cable would be is 25ft. Would it even effect gaming? (i am not some pro gamer so a few millisecond is nothing to me.
Let me know what your thoughts were. Would like to know.
if you used thunderbolt it would be fine because USB, and any display connection are not suppose to be over 10 feet
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
The length doesn't increase lag (electricity travels at basically speed of light) although voltage drop is the issue with signal loss (longer a wire the higher the resistance). 16ft is about he max for a usb cable, long as hdmi cables are just really fragile.
Running over thunderbolt seems to be a much better option.
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
So how would I set this up? Use some adapter at the pc to Thunderbolt then adapter again at the desk? Any idea on what i need to do this? oh and thanks so far.
