I'm getting back at the wonderful world of PC after a few years stuck with a laptop soon, I have the desire to have a very high end gaming rig and will buy next week an i5 6600k and a z170M/PLUS, the system will be installed on a Sharkoon ATX VG4-W
Which seems to offer a nice cooling, it has fans making the airs go in in front and out on the back, just to finish the build, it's a 700w PSU 8gb ram in dual channel and a GTX 560 Ti (Yeah I ran out of money for this go but I plan a gtx1060 futurely, as for I plan going with a 2560x1080 monitor); I accept any suggestions about this stuff but let's go to the real matter here:
I really ran out of money with the stuff bought and I couldn't make it to a proper heatsink for the cpu, all I have is a given to me Intel Core 2 Duo Stock Heatsinker, and I got like a 3 dollars thermal paste. I would like to know if this considerably old heat-sink (It is however completely clean, well cared) be enough for the i5 6600k for like a month or two, not planning on OC it before I can buy a proper heat-sink, also I accept suggestions on possible ones, I prefer Air ones, water seems too much trouble to me.
This is my first post ever so if I made some mistake please let me know.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/698320-a-situation-with-cooling/
from memory; there was a huge difference between the dual and quad core heatsinks; the quad was twice the size. The 2-core core2duo was 65W TDP, your i5 is 91W TDP. Also i dont know if the heatsink will fit on the socket/motherboard
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/698320-a-situation-with-cooling/#findComment-8934500
c2de6600_cpuhsk.jpgIt looks fairly closer to a nowadays i7 stock cooler than the i5 one, its bottom is made of copper.
Personal Desktop":
https://linustechtips.com/topic/698320-a-situation-with-cooling/#findComment-8934517
Thats looks like the quad core cooler. the dual core one was tiny.
http://www.anandtech.com/show/2658/3
Quote
From left to right: 45nm Core 2 Duo cooler, 45nm Core 2 Quad cooler, 45nm Core i7 Coole
You should be good if the pins fit?
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/698320-a-situation-with-cooling/#findComment-8934557
they probably do or so it seems from the picture of the motherboard, so perhaps this is a quad core one, it's strange because it was working for a core 2 duo, regardless lucky me, and running this heatsink for 2 months won't stress out the CPU then? This is good news, Also @Abyssal, I looks at the fan it seems like the natural high end choice, though I'll admit I was considering something flat for looks like the spoiler down there, for a "safe overcloacking" maybe a 4,3ghz on this 6600k would it make too much of a difference between picking something like this HTPC-200 instead?
Personal Desktop":
https://linustechtips.com/topic/698320-a-situation-with-cooling/#findComment-8934713
If your core 2 duo heatsink fits the holes on the skylake board, it'll do fine. Might be slightly louder and warmer, but definitely won't burn anything.
PC 0: Pinky 2.0
Ryzen 9 5950x — 64GB G.Skill Ripjaws 5 @3600Mhz CL14-13-13-28-288 — ROG Crosshair 8 Dark Hero — RX 6900 XT — Hardline Loop — Sabrent Rocket 4.0 2TB — Samsung PM961 1TB  WD Blue 4TB HDD — Corsair AX1500i — Thermaltake Core P5
PC 1: Pinky (Yes that is her name) Here's the build
Xeon E5-1680V3 — 64GB G.Skill Ripjaws 4 @2400Mhz — MSi X99A Godlike Gaming — GTX 980Ti SLI (2-WAY) — Hardline Loop — Samsung 950Pro 512GB — Seagate 2TB HDD — Corsair RM1000 — Thermaltake Core P5
PC 1.1: Pinky (Mom Edition) Here's the build
i7-5960X — 64GB G.Skill Ripjaws 4 @2400Mhz — MSi X99A Godlike Gaming — GTX 980Ti SLI (2-WAY) — Hardline Loop — Sabrent Rocket 3 1TB — Samsung Q 870 Evo 4TB — Corsair HX850i — InWin S-Frame #190
PC 2: Red Box/Scarlet Overkill (Dual Xeon)
Xeon E5-2687W x2 — 96GB Kingston DDR3 ECC REG @1333Mhz — EVGA Classified SR-X Dual CPU — GTX 1070 SLI (2-WAY) —Hardline Loop — Samsung 750 EVO 256GB — Seagate 2TB 2.5" HDD x3 — Self-Built Case
https://linustechtips.com/topic/698320-a-situation-with-cooling/#findComment-8935042
  Reveal hidden contents
What is your budget for cooler and sites you will be looking at? Budget with same currency as sites, if you can. I think you are good with any LGA115x stock cooler for now and you can downclock or set manual voltage to limit temps. For cooler I would go for something bit better than cooler you've linked. Its for non-OC builds and really limited spaces like HTPCs. Your case can fit 160mm coolers. If you still want downdraft style, there are good options from Cryorig, Phanteks and Noctua.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/698320-a-situation-with-cooling/#findComment-8936677
I don't have much trouble with budget, here in my country(Brazil, currency BRL) payment of salary is made monthly that's why I might have to wait a month or two with the stock cooler, but after that I really want a cooler capable of a decent but not exaggerated OC on the 6600k, I do prefer the flat style but I won't let aesthetic get over performance, I gave some looks and the CoolerMaster Hyper T4 RR-T4-18PK-R1 seems interesting for its price, any thoughts on it?
Personal Desktop":
https://linustechtips.com/topic/698320-a-situation-with-cooling/#findComment-8936786
5 hours ago, Princess Cadence said:
T4 is good basic cooler. There are better ones, like Cryorig H7 and M9i. But it will do the job and let you OC a bit.
https://linustechtips.com/topic/698320-a-situation-with-cooling/#findComment-8937927
