So, my Pro 4 is using a lot of battery power.
According to BatteryBar the discharge rate is usually between -7000mW and -10000mW.
Why is it so high?
Note - I'm using the core i7-6650U model (15w TDP)
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/696467-is-this-power-consumption-high/
Is there something using the [SSD], CPU, or GPU? Perhaps the Wi-Fi module is over-working?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
GPU:
Usual Hardware acceleration in Word, Powerpoint, OneNote
Edge
Possibly WhatsApp
Possibly VS 2015
CPU:
Possibly Edge
Possibly VS 2015
Wi-Fi:
Lots of browsing and saving files using OneDrive.
that's less than my laptop at idle (~9 or 10W)
4 minutes ago, AluminiumTech said:
snip
Have you tried running a battery report through powercfg? Or would you rather try Battery Monitor?
Edit:
powercfg /batteryreport
I believe the file will be saved to your documents folder.
Considering my "laptop" has a 39Whr battery this is really annoying.
rip, mine started with 65 but I upped it to 95 :D
Edit:
I've already done a battery report.  What info do you want from it?
Cycle count: 84...... RIP
Design Capacity: 38,152mWh
Full charge Capacity: 36,682 mWh
Also...........
