should be ok with win 8. problems with keyboards are usually with mac or linux and thats just for backlights or media keys which usually have workarounds that are easy with Unix based systems
ψ ︿_____︿_ψ_
Yes. Windows has a ton of backwards compatibility features. Also, Windows 8 is not that old.
Quiet Whirl | CPU: AMD Ryzen 7 3700X Cooler: Noctua NH-D15 Mobo: MSI B450 TOMAHAWK MAX RAM: HyperX Fury RGB 32GB (2x16GB) DDR4 3200 Mhz Graphics card: MSI GeForce 3080 GAMING Z TRIO PSU: Corsair RMx Series RM750x Case: Be quiet! Pure Base 600
Buffed HPHP ProBook 430 G4 | CPU: Intel Core i3-7100U RAM: 4GB DDR4 2133Mhz GPU: Intel HD 620 SSD: Some 128GB M.2 SATA
Retired:
Melting plastic | Lenovo IdeaPad Z580 | CPU: Intel Core i7-3630QM RAM: 8GB DDR3 GPU: nVidia GeForce GTX 640M HDD: Western Digital 1TB
The Roaring Beast | CPU: Intel Core i5 4690 (BCLK @ 104MHz = 4,05GHz) Cooler: Akasa X3 Motherboard: Gigabyte GA-Z97-D3H RAM: Kingston 16GB DDR3 (2x8GB) Graphics card: Gigabyte GTX 970 4GB (Core: +130MHz, Mem: +230MHz) SSHD: Seagate 1TB SSD: Samsung 850 Evo 500GB HHD: WD Red 4TB PSU: Fractal Design Essence 500W Case: Zalman Z11 Plus
