NEED HELP! (Will it bottleneck??)
Go to solution Solved by i_build_nanosuits,
4 minutes ago, bennychun said:
I was searching the web, and the base model RX480 8Gb is about U$30.00 cheaper than the Strix 1060 6Gb... Is it worth it?
Because maybe I`ll be able to overclock the strix card... I don't know, never done it before
no, reference RX 480 with the plastic blower cooler is a piece of shit...it overheat and trottle...do not buy that.
If you overclock the GTX 1060 it will then be faster than RX 480...and it's very easy...if you plan on overclocking the card, i would tend to go with the 1060 because it overclock more than the 480.
So, I am finally going to swap my current GPU (HD 6570) for a new one!
I'm thinking about buying the GTX 1060, but I don't know if this GPU is going to be bottlenecked by my CPU, which is an i7 2600.
I plan on playing the most recent games (Battlefield 1, Rocket League, Overwatch, The Witcher 3...) on 1080p.
Thanks a lot! :)
https://linustechtips.com/topic/694343-need-help-will-it-bottleneck/
No (Not noticeable at least).
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
Just now, Dawson Wehage said:
May be like 2 fps but pretty much no you shouldn't be bottlenecked.
Thats basicly what I said.
PSU Tier List
My specs
PC:
Peripherals
3gb and 6gb are similar, but 3gb is not much Today, and since you should be using it for at LEAST 2 years, 6gb is better.
And i7 2600 is a good CPU, dont worry.
8gb of ram is also fine, it is the budget sweetspot.
Ultra is stupid. ALWAYS.
  • 3 weeks later...
5 minutes ago, bennychun said:
sooo i just watched Hardware Cannucks video... and is the RX480 better than GTX1060??
I am about to buy it next week
They trade blows. It really depends on what games you play. AMD did bring their game up though. What matters more is what price you can get a 1060 6GB vs 480.
Also, your CPU is fine.
On 2016-11-21 at 4:26 PM, bennychun said:
-should I get the 6 gb or the 3 gb model?
-and which brand is the best(I dont really care for the looks of the GPU)?
-Also is 8GB RAM enough
-6GB
-MSI gaming
-Yes
2 minutes ago, bennychun said:
do you still think the Nvidia card is better?
depends on price i would go with the cheaper between the 1060 6G or RX 480 8GB...both are very similar in performance.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Just now, bennychun said:
what about the rx480? do you think it is a better card??
my previous post was edited about that...
are you in the US?
Thanks! But can Dx12 games be improved on a 1060 just by software updates?
yes and no, it depend on the game, the 1060 is not far behind even in DX12, and most DX12 stuff so far is either broken, or perform worse than DX11...when both are supported DX11 usually perform better both on amd and nvidia, and it will take a while before DX12 becomes the norm for games, and also, it will still depend on the game because some favor nvidia and some favor AMD and this will still be true in DX12 titles...so, yes and no :)
i would base my choice on price, or check what games you play and take the card that perform better in those titles because those cards trade blows from game to game.
