NEED HELP! (Will it bottleneck??)
Solved by i_build_nanosuits,
4 minutes ago, bennychun said:I was searching the web, and the base model RX480 8Gb is about U$30.00 cheaper than the Strix 1060 6Gb... Is it worth it?
Because maybe I`ll be able to overclock the strix card... I don't know, never done it before
no, reference RX 480 with the plastic blower cooler is a piece of shit...it overheat and trottle...do not buy that.
If you overclock the GTX 1060 it will then be faster than RX 480...and it's very easy...if you plan on overclocking the card, i would tend to go with the 1060 because it overclock more than the 480.
