ideal temps for GPU ?
Go to solution Solved by Oshino Shinobu,
Basically below 90C tends to be safe. Recent Nvidia GPUs tend to like running at around 80C from what I've seen.
Not over 90 and not over 80 will usually give jou a longer lifetime (~75-80 is default for most gpus
not over 70 is considered very nice but not realy possible unless u use water or have sounds like a plane taking of xD
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/693748-ideal-temps-for-gpu/#findComment-8892926
Depends on the GPU and preference... I'd say for me personally I don't let any of my cards run near 75 c at that point some cards throttle hard (especially amd cards) but some one else would tell you 68 c is too hot when that's actually the avg temp for a gaming load (in my case). Any thing above 88 c is death territory for desktop gpu's (mobile gpu's can hit 90c  regularly and not have any serious damage)
Main PC:
CPU: Ryzen 5 3600  | GPU: RTX 2060 | PSU:  | Memory: Corsair Vengeance RGB 3200Mhz 16GB | OS Drive: Western Digital Black NVMe 250GB | Game Drive(s): Samsung 970 Evo 500GB | Motherboard:  | Case: Fractal Design Define R6 | Monitor(s):  | Keyboard:  | Mouse: Steelseries Sensei 310
NASUS (NAS)
CPU: Intel Xeon X3440 | Motherboard: Super Micro X8SIL | Memory: 16GB DDR3 1066Mhz ECC UDIMM | HBA: Dell Perc H200 (Flashed to IT Mode) | Drives: 3x 16TB Seagate Exos x16, 2x 6TB Seagate Enterprise, 1x 6TB WD RED
RENEKTON (NAS)
CPU: Intel Core i5 4570TE | Case: Fractal Design Define S | Memory: 16G DDR3 1333Mhz SODIMM | HBA: LSI 1068E (Flashed to IT Mode) | Storage: 4x 3TB Hitachi, 2x 3TB WD RED
https://linustechtips.com/topic/693748-ideal-temps-for-gpu/#findComment-8892929
so long as it is under the temp at which it starts to throttle then it is all good.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/693748-ideal-temps-for-gpu/#findComment-8892936
