2 minutes ago, Gamergod88 said:
Can I use usb sticks in raid0? I came up with an idea to use 2 usb sticks in raid0 for my 13 year old pc boot drive to make it boot fast an install chrome os making this pc usable again.
no. afaik.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883661
Yeah you can, the 8-Bit guy did a video on it.
Not that it's a very smart way of doing it, in the end an SSD will be cheaper
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883695
1 minute ago, Gamergod88 said:
Rip hopes and dreams :<
you can, but its impractical
https://www.youtube.com/watch?v=dougISKs2vQ
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883699
Just now, Gamergod88 said:
I have seen this, but can't get it done on my win10 pc
watch the video, , it may not work anymore
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883709
the slow boot makes this pc unusable? really?
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883787
slow boot and the fact that he can't handle windows anymore, but chrome os will save me, won't it?
idk for chrome os but i guess now that my 1080p crysis 3 pc is for the junk as it needs like 3 minutes to boot..... xD JK
Just make clean install or windows XP or even 7 and i asure you it will run fine like before  (i made windows 7 home to work on pentium D without much lag (and it lags cuz it had only 1 gb of ram so if you have more you are good to go))
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883843
I have 1 Gb ram too, and I have just installed win Xp. It is having hard time browsing web, so that's a thing :D
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883860
Just now, komar said:
yeah - xp doesnt have support anymore so this will cause some lag :P
also i really hope you did 100% wipe of that drive and then installed the drivers you need
and last but not least clean this thing from dust and anything else that could be there
Yea, wiped the drive and cleaned the dust. Should i try running win10? Will not solve the long boot problem tho :/
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883876
ChromeOS is very good i have a Chromebook with 2gb of ram and its never failed me yet. If I we're you I would try grab an ssd during the black Friday sales.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883918
There are no sales in Lithuania :D.. And it would be more fun to do something like this.
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883928
ssd fan boys everywhere.....
anyway even the usb raid is not a good idea beacuse  even if you get it to work somehow... how many mb/s can you squeeze from a usb 2.0 max? xD (and i bet you dont even have 2.0) idk  IDE speed but i know usb 2 - tops 30
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8883942
Well seeing as the slowest part of the pc is its main storage it makes sense to upgrade that part first. It's only now with pci ssd that the storage bottleneck is going away.
https://linustechtips.com/topic/692770-usb-stick-raid0/#findComment-8884023
