So for me using the same water coOling block on the 6700k and 6850k I get about 20 degrees cooler on the 6850k with it at 4.5 ghz and the 6700k at 4.7ghz. is this normal? my friend keeps saying that the cpu even though it's bigger should be hotter but the 3930k I had once was also very cool. I think the larger surface area takes away heat alot faster. what do you guys think ? I got 50 to 55c on the 3930k 60 to 68 on the 6850k and 80 to 85 on the 6700k.
https://linustechtips.com/topic/690433-cpu-temps/
Because 6850k has SOLDERED heatspeader and 6700k just uses goo glue
Just 2 cents
https://linustechtips.com/topic/690433-cpu-temps/#findComment-8857908
5 hours ago, Shadow_Storm56 said:
6850k I thought was not soldered.
All CPUs for X99 are soldered to IHS.
And because of that, you get 20°C lower temps compared to those CPUs with TIM inside.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/690433-cpu-temps/#findComment-8859009
