HYPER EVO 212 HELP!
Go to solution Solved by ThinkWithPortals,
Tell your friend he's stupid.
And yes, non-conductive electrical tape will work.
Other systems I've built:
https://linustechtips.com/topic/689873-hyper-evo-212-help/#findComment-8851235
2 minutes ago, Powis21 said:
Why would he take it off may i ask? It comes pre taped for our convienience.
Yup Ik, he thought it was something to remove, his pc did not start I diagnosed the pc and narrowed it down to the CPU or mobo, it turns out to be both as he took that sticker off, luckily for him he was extremely fortunate to get replacements without charge
https://linustechtips.com/topic/689873-hyper-evo-212-help/#findComment-8851263
3 minutes ago, Megah3rtz said:
don't the instructions say don't remove the cover? yes they do.
You read those then? Come on, you need some risks in life :)
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/689873-hyper-evo-212-help/#findComment-8851289
