As the title suggest I'm planning on building a computer soon hopefully this is the parts i have https://www.amazon.com/gp/cart/view.html/ref=lh_cart_vc_btn
  • Kingston HyperX FURY Black 8GB Kit (2x4GB) 2133MHz DDR4                               $44  US
  • MSI Computer GTX 1060 3GT OC NVIDIA GeForce 3GB                                         $205 US
  • EVGA SuperNOVA 550 G2, 80+ GOLD 550W, Fully Modular                                   $83  US
  • MSI Intel Skylake B150 LGA 1151 DDR4 USB 3.1 Micro ATX                                     $60  US
  • Intel 3.70 GHz Core i3-6100        $120 US
  • WD Blue 1TB SATA 6 Gb/s 7200 RPM 64MB Cache 3.5 Inch                                     $50 US
  •        $562 US
I still need a case, monitor and keyboard trying to keep it all around 700 any recommendations would be great. I also am going to need windows,
i do however have access to laptops with windows 10 on them i read somewhere that it is possible to copy it I have a flash drive so if anyone can
give information on that as well would be appreciated =3
https://linustechtips.com/topic/686982-first-build/
Just now, Pew Pew Dino said:
W1 psu?
The PSU you have chosen is shite. Get something with at least decent quality. I'd recommend the Corsair CX450M.
Main Rig: CPU i7-4790k / MOBO Asus Z97-Pro (Wifi-AC) / RAM 16GB HyperX Fury 1866 MHz / CPU COOLER Dark Rock 3 / GPU Asus GTX 1070 Strix  / CASE Evolv ATX Tempered Glass / SSD Crucial MX200 250GB / HDD  WD Black 1TB + WD Blue 3TB / PSU EVGA 750G2 / DISPLAYS 2x Dell U2414h / KEYBOARD Corsair K70 RGB Cherry MX Brown / MOUSE Logitech G602
Laptop: Dell XPS 15 / i7-6700HQ, 16GB RAM, 512GB SSD, GTX 960m, 1080P Display
Cheap Windows/Office Keys
https://linustechtips.com/topic/686982-first-build/#findComment-8819611
4 minutes ago, Pew Pew Dino said:
As the title suggest I'm planning on building a computer soon hopefully this is the parts i have https://www.amazon.com/gp/cart/view.html/ref=nav_cart.
  • Ballistix Sport LT 8GB Kit (4GBx2)        $54  US
  • EVGA 500 W1, 80+ WHITE 500W        $33  US
I still need a case, monitor and keyboard trying to keep it all around 700. I also am going to need windows, i do however have access to laptops with windows 10
on them i read somewhere that it is possible to copy it I have a flash drive so if anyone can give information on that as well would be appreciated =3
Pay $50 for the PSU and live to tell about it! :P
Grab a CX450M from Corsair. https://www.amazon.com/dp/B01B72VXE6
You're paying a bit much for the 1060 3GB. A $210 RX 480 is better. https://www.amazon.com/dp/B01M1YE9TD/
You're also paying a lot for RAM. Try to get a kit for $40, more than that is too much.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/686982-first-build/#findComment-8819628
5 minutes ago, Thread212 said:
is that armpit? your avatar?
I'm thinking the same...
https://linustechtips.com/topic/686982-first-build/#findComment-8819656
It's a blue brick wall with a broom. :)
Computer Specs:
https://linustechtips.com/topic/686982-first-build/#findComment-8819658
Yes its a blue brick wall with a broom how are they seeing armpit hair kappa
I though it was a hairy crotch. :P
Use the quote function so we get notified!
Computer Specs:
https://linustechtips.com/topic/686982-first-build/#findComment-8819671
Just now, Thread212 said:
I am sure u are uchiha clan member because i fell at that illusion.. lol
Lol
I also fell at first, but I passed my save versus enchantment
Computer Specs:
https://linustechtips.com/topic/686982-first-build/#findComment-8819674
Here's some RAM for $40 https://www.amazon.com/dp/B013H7Q86C
Computer Specs:
https://linustechtips.com/topic/686982-first-build/#findComment-8819681
Changed the Ram and PSU isnt the 1060 and 480 around the same performance?
https://linustechtips.com/topic/686982-first-build/#findComment-8819706
15 minutes ago, Thread212 said:
EVGA 500 W1, 80+ WHITE 500W    dont buy that for 1060..
If u can spend more get the super flower leadex 550w or evga g2 550w..
but if u cant then get corsair CXM 550W..
Any monitor and case recommendations psu and ram were updated also it is suppose to look like a hairy crotch
https://linustechtips.com/topic/686982-first-build/#findComment-8819717
11 minutes ago, Thread212 said:
Budget?
for the case i recommend.
-NZXT S340
-NZXT H440
-Fractal Design define r4
-Or Phanteks Enthoo Evolv tempered glass if your bank account can handle.
I am not an expert in monitor.
But i prefer buying an 60Hz 1080p Ips monitor for casual gaming.
Or u can consult @Glenwing for more information.
Thxz m8 imma msg him
https://linustechtips.com/topic/686982-first-build/#findComment-8819793
The 1060 6GB is a bit better than the 480. The 1060 3GB is a bit worse than the 480. It's also got 3GB which isn't enough for max settings on some games. Given the same price, I would choose RX 480 4GB almost always.
Computer Specs:
https://linustechtips.com/topic/686982-first-build/#findComment-8819827
I'd get this PSU
http://pcpartpicker.com/product/DPCwrH/seasonic-power-supply-ssr550rm
It's top rated, more than enough power, and you'll save yourself $40.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/686982-first-build/#findComment-8819911
