a hyper 212 will be good, but will only get you so far.
AIO coolers are good, depending on what one you get.
I myself use a h105, put the fans on low until about 60c and then they kick in, which is pretty much never.
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
https://linustechtips.com/topic/686806-air-vs-water-cooling/#findComment-8817904
What cpu are you cooling?
Where are you shopping/located? Budget?
The 212 Evo performs similarly or better than some 120mm AIO's depending on the scenario and the AIO's in question.
https://linustechtips.com/topic/686806-air-vs-water-cooling/#findComment-8818057
1 hour ago, JasonLavender said:
I am trying to choose a cooler. Is there a difference between a low end air cooler (Hyper 212 evo) and a 120/140mm water cooler? Thanks.
Doesn't apply to low end, but I just posted some results switching from H115 to Nocuta D15.
Sole Proprietor of Pinnacle Gaming, forging record breaking PCs at an unbeatable (literally) value feat: M2 drives, "delidded" cpus & gpus, record breaking speeds (hwbot), platinum PSU (always tier one),  premium motherboards, now with RGB LIGHTING, and all at a budget price, dare to compare even vs building yourself
https://linustechtips.com/topic/686806-air-vs-water-cooling/#findComment-8818346
Small AIO is only realistic option if A] you are for the looks B] have limitations on cooler size/height. Otherwise they are overpriced for the performance and make much more noise than air cooler of same performance.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/686806-air-vs-water-cooling/#findComment-8821884
