The 6100 will most certainly not bottleneck the 1060, though I don't know what kind of FPS you'll get with it. You should try to research some benchmarks on a per-game basis to see how that i3 does in whatever games you want to play.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8807259
4 minutes ago, begadelavela said:
BF1,BF4,
In 64 man servers, probably.
Quote
World of Tanks
Relevant:
While it did get improved, I still think the i3 would be enough for wot.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8807277
10 minutes ago, begadelavela said:
Hi guys I want to know difference between i3 6100 and i5 6500 in gaming with 1060 in games like BF1,BF4, World of Tanks, CS GO, RaiinbowSS, Ghost recon Wildlands, Forza Horizon 3... Will i3 6100 bottleneck with 1060 and that stuff. THX Guys
get the i5 since it is a quad core compared to a dual core.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8807282
Depends. Pretty much any CPU can bottleneck any of those games, like if you try to run SLI with GTX 1080s at 1080p because lol.
The i3-6100 is an excellent CPU for the money that should pull at least 60 FPS on medium to high settings with little stuttering for most of those games with that 1060.
That said, the i5-6500 is consistently better and you wouldn't be having this discussion if you were going to get it. If you can afford it, I'd recommend getting it, but it's not a big deal right now. I'd consider upgrading later, though.
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8807317
8 minutes ago, begadelavela said:
So WoT is really demanding or?
 What he is trying to convey is that it's mostly a single threaded workload, meaning that the extra cores of the i5 would be sitting around, watching, as a single core does most of the work.
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8807319
9 minutes ago, Dawson Wehage said:
u really need to change your profile picture
uhm.... why? xD
Old Rig
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8807324
Just now, SeanAngelo said:
uhm.... why? xD
Don't listen to him, he's a derp.
Your profile picture is 10/10.
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8807326
What about i5 6400?
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8807350
Lookin at 400 fps at 1080
lttstore.com
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8808123
No, it had one of the worst multi threading implementations I have seen pre 9.14. It runs easily on low end hardware.
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8808964
lol the i3 will bottleneck in BF1. My i7 6700K is at 100% in 10vs10 fights :o
Main PC: R7 3700X / Gigabyte X570 I Aorus Pro Wifi / Radeon RX 5700 XT / 32GB DDR4-3200 / 250GB & 2TB Crucial MX500 (in HP Prodesk 400 Case)
Laptop: R5 2500U / Radeon Vega 8 / 8GB DDR4-2400 / 500GB SK Hynix BC501 (HP Envy x360 13)
My little Server: i7-7700 / Asrock H110M-ITX / 24GB DDR4-2400 / Samsung 860 Pro 250GB & Seagate Firecuda 2TB / VMware ESXi 6.7
(Don't tell me i should Name them, i don't want to ^^)
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8808979
The i3 will not bottleneck those games, and will be fine with most games currently released. BUT. The time will come when the i3 will bottleneck and the i5 won't, so it's worth the extra money not just by performing better now but performing better for LONGER.
Think like a summation, if you compare current performance per dollar it doesn't win but if you sum lifetime performance per dollar the i5 wins.
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8809209
Yes it will bottleneck.
i7 9700K @ 5 GHz, ASUS DUAL RTX 3070 (OC), Gigabyte Z390 Gaming SLI, 2x8 HyperX Predator 3200 MHz
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8809449
An i3-6100 for battlefield 1 and you think it can sustain a GTX 1060 which is basically the performance of a GTX 980 with more video memory?
yeah, no...even my i7-4770K is seeing 85 to 100% loads sometimes playing battlefield 1 multiplayer:
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8810476
Yep I got 6700K @ 4.5 GHZ and sometimes it reaches 80-90%, never saw higher tho yet, but its obvious theres somthing wrong in optimisation, unless BF1 brings the time of the 8 cores + gaming performancexD
https://linustechtips.com/topic/685749-will-it-bottleneck/#findComment-8810855
