if it has a pcie slot it would work. and make sure that the mobo can supply enough power
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805763
4 minutes ago, Jordan Gulrajani said:
Hey there Oswin. Thanks for replying. I researched this graphics card of mine which is the gtx630 2GB and it is a has a PCI-E express slot 3.0 which is 16xslot I guess. and what is a mobo by the way?
It should work, given there isn't some pre-existing issue with your current hardware.
Mobo = short for motherboard
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805781
That's an Ivy Bridge motherboard, right? Then you're fine. Anything you're using now for your power supply is also sufficient.
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805783
My power supply has a 600W but it has to pci-e connectors for high card gaming. So will this be enough power to power up the GTX1050Ti?
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805796
Hi there. Thanks for replying and the details you have given to me. So the GTX1050Ti is a good choice for my prebuilt system?
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805798
Hello Jordan!
The 1050ti is a basic card and not the most powerful, it will most likely suit your board provided that you can power it up.
As long as you know how powerful it is and if it gives you the results you are looking for in game you are good to go.
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805824
1 minute ago, MVPernula said:
Hello Jordan!
Thanks for the awesome reply Pernula. So the GTX1050Ti is a good choice for me since I am budgeting my money for PC GAMING. I have another question can this card run triple A title games at ultra settings in 1080p resolution at 30FPS above?
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805833
yes.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805866
The card can run 1080p, not all AAA titles however. At least not in Ultra.
Check this video out!
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805867
Thanks Pernula. This video helped me on how this card runs modern games in a given resolutions and settings. Again thank you so much ^_^ now I can decide this is the card that I am looking for
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805892
I'm glad to have been able to help, feel free to ask again if anything comes up!
https://linustechtips.com/topic/685604-gtx1050ti-compatibility/#findComment-8805902
