1. Budget & Location
USD$ 800-1200$ I'm fine with getting closer to the 1200$ range if it means I'll get a system I'll be happier with in the long run.
2. Aim
Gaming mostly, though I do a fair amount of photo editing (photo shop), and I would like to get video editing as well.
3. Monitors
One 1080p monitor for now, open to adding more in the future.
4. Peripherals
Already have Keyboard, mouse ect.
5. Why are you upgrading?
I only got into PC gaming about a year ago. I bought a Asus g551jw, a good laptop,but it can only do so much.
Any insight will be greatly appreciated.
Parts list:
power supply: Corsair CXM series CX550m 550W 80 plus bronze
amazon link: https://www.amazon.com/dp/B01B72W0A2/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3SKZ54WN0V3Q6&coliid=I1PYDK8224VIBE&psc=1
Hard drives: Samsung 580 EVO 500GB m.2 ssd
amazon link: https://www.amazon.com/dp/B01M0SL4V1/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3SKZ54WN0V3Q6&coliid=IF5G74KTE5DM9
Seagate 2TB Barracuda Sata 6GB/s 128MB Cache 2.5-Inch 7mm Internal
amazon link: https://www.amazon.com/dp/B01LX13P71/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3SKZ54WN0V3Q6&coliid=I3T81OYA3QHL4Z&psc=1
Fans (case comes with two fans, I plan on adding these, will probably swap the original case fans in the future)
Corsair Air Series SP120 High Performance Edition Twin Pack Fan
amazon link:
https://www.amazon.com/dp/B007RESFYK/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3SKZ54WN0V3Q6&coliid=I2TUIC4FZFE7EQ&psc=1
Case:
MasterBox 5 Black & White Mid-tower with Internal Configuration, E-ATX Support, and Nine SSD mount positions
amazon link:
https://www.amazon.com/dp/B01HDUVMBU/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3SKZ54WN0V3Q6&coliid=I29B68349KX0TF&psc=1
RAM:
Corsair Vengeance LPX 16GB DDR4 3000 C15 for DDR4 Systems - White
amazon link:
https://www.amazon.com/dp/B01EI5Z2T6/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3SKZ54WN0V3Q6&coliid=I1IES4T0N93U9O&psc=1
Motherboard:
ASUS Z170-A ATX DDR4 Motherboards
amazon link: https://www.amazon.com/dp/B012NH05UW/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3SKZ54WN0V3Q6&coliid=I2GBNXMK3XNGL0&psc=1
Video card:
Gigabyte GeForce GTX 1060 WINDFORCE OC 6G (GV-N1060WF2OC-6GD)
amazon link
https://www.amazon.com/dp/B01JNUO6BG/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3SKZ54WN0V3Q6&coliid=I1QBM9UKRD2JW9&psc=1
CPU:
Intel Core i5 6600K 3.50 GHz Quad Core Skylake Desktop Processor, Socket LGA 1151, 6MB Cache
amazon link:
https://www.amazon.com/dp/B012M8M7TY/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=3SKZ54WN0V3Q6&coliid=I1ARQLZ4SPKAOU&psc=1
Heatsink:
Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
amazon link:
https://www.amazon.com/dp/B005O65JXI/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=3SKZ54WN0V3Q6&coliid=I1OQCIZ9JMVKR&psc=1
https://linustechtips.com/topic/685601-putting-together-first-pc-build/
PCPartPicker part list: http://pcpartpicker.com/list/dHRqbj
Price breakdown by merchant: http://pcpartpicker.com/list/dHRqbj/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.89 @ OutletPC)
Motherboard: MSI B150M MORTAR ARCTIC Micro ATX LGA1151 Motherboard  ($81.98 @ Newegg)
Memory: Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory  ($89.99 @ B&H)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($94.89 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($73.80 @ OutletPC)
Video Card: Asus GeForce GTX 1060 6GB 6GB Dual Video Card  ($269.99 @ B&H)
Case: NZXT S340 (White) ATX Mid Tower Case  ($66.69 @ SuperBiiz)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($62.99 @ SuperBiiz)
Total: $935.22
Generated by PCPartPicker 2016-11-04 02:09 EDT-0400
i name it polar bear... for a good reason
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($236.98 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard  ($112.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($74.99 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($69.98 @ B&H)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.33 @ OutletPC)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Monitor: Asus VG248QE 24.0" 144Hz Monitor  ($242.99 @ Best Buy)
Total: $936.81
GPU From the EGG - Sapphire Fury X
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202186&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
$1207 ish
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
PCPartPicker part list: http://pcpartpicker.com/list/kcxyxY
Price breakdown by merchant: http://pcpartpicker.com/list/kcxyxY/by_merchant/
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.88 @ OutletPC)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($77.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory  ($83.31 @ Amazon)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($61.99 @ NCIX US)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($74.49 @ Newegg)
Video Card: Asus GeForce GTX 1070 8GB Video Card  ($433.98 @ Newegg)
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Newegg)
Total: $1148.59
Generated by PCPartPicker 2016-11-04 02:29 EDT-0400
something bit better
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
