So windows 7 or windows 8 ... I have just got my PC and am starting to build now but I need an OS but not sure which one to go for. What do you guys think plus could you link me some good prices for them ( in uk) I didn't think they were so expensive
AMD FX-8350 II ASUS R9-20x DCU2 TOP II Fractal Design R4 II Samsung 840 Evo 250gb SSD II Gigabyte 990FXA UD-3 II 8GB Corsair XMS II Cooler Master Seidon 120mm II ACER H236HL Monitor II Corsair K70 II Razer Deathadder II Kinect II
Go check out my Build Log for my "Home Made Gaming POD"
http://linustechtips.com/main/topic/83872-home-made-gaming-pod-build-log/
https://linustechtips.com/topic/68366-what-operating-system/
I could give you a link to get it....but...it might be against CoD :)
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/68366-what-operating-system/#findComment-936578
Windows 8.
Desktop: Intel i5-3570K (stock) | Asus Sabertooth Z77 | G.Skill RipJaw 16GB 1600MHz | Samsung 840 120GB | EVGA GTX 680 SC+ 2GB | Fractal Design R4 | Windows 8 Pro (soon to have dual boot Mac OS X)
Retina Macbook Pro : Intel i7-3840QM | 16GB 1600 MHz | 256GB SSD | Nvidia GT 650M 1GB | Mac OS X 10.8.5
https://linustechtips.com/topic/68366-what-operating-system/#findComment-936583
Win 8.
They aren't expensive at all. You even happen to stumble upon one while on the internet.
but 8 is only 10$ more than 7 and worth it.
Like 80 pound for a piece of software
https://linustechtips.com/topic/68366-what-operating-system/#findComment-936595
Why not try linux? Or OSX? Or you could try my personal favourite windows 95. Seriously I have a install disc of 95 right next to me. My point is try around ALL of the options not just ones from microsoft. A good way to do this is to go to a store like PC World or currys and test out the OSes running on the laptops they have there. To test linux download a distro onto a usb and boot to it. For OSX go to the apple store.
i9 25.6 GHz with NeuronThreading, 256gb 6000 MHz RAM, GTX 990 OC 3024MHz 12gb, Skeletal X99 motherboard, 1 Petabyte SSD, Fractal Design Humaniod R1 Case, Herbivore 10,000W PSU, Noctua NF16 LP Derma Cooler.
Probably the only Star Citizen player who is planning on a career in Journalism instead of piracy, mining, trading, exploration, military, station management, etc.
Generation 0: The first time you see this add 1 to the number and copy it into your sig. Consider it a social experiment.
https://linustechtips.com/topic/68366-what-operating-system/#findComment-936685
I'd go with 7. I can't stand 8 to the point that I run it in a VM on top of 7 to get the one feature I want from it - SMB 3.0. The point I'm making is that it's terrible enough for that inconvenient setup to be preferable to me actually having to use windows 8.
8.1 is an improvement but it's still intolerable for me. Until they back off with the stupid UI I'm out. If Windows 9 is the same I'm gonna move to Linux and stay there. I already use Ubuntu on every other device I own, only DirectX and the fact that 7 is still better than Ubuntu keeps me on Windows for my desktop.
https://linustechtips.com/topic/68366-what-operating-system/#findComment-936705
Another vote for Win 8, if you don't like the UI just download one of the many start menu addons, turning it into Win 7 only better & faster.
CPU: i5 4690K  CPU Cooler: Corsair H100   Motherboard: Gigabyte Z97X UD3H   Memory: G.Skill (2 x 4GB) DDR3-1866   Storage: Samsung 830 Series 128GB 2.5" SSD/Seagate Barracuda 1TB 3.5" 7200RPM   GPU: EVGA GeForce GTX 660 Ti SC 2GB   Case: Cooler Master CM 690 II (Black) ATX Mid Tower   PSU: CORSAIR Enthusiast Series TX650M 650W 80 PLUS BRONZE Certified   Optical Drive: MSI DH-24AAS-17 R DVD/CD Writer   Operating System: Windows 10 Pro (64 bit)
https://linustechtips.com/topic/68366-what-operating-system/#findComment-936782
not all Linux distros are free
Only Enterprise systems cost, and they are designed for servers, also the ISOs are publicly available still, just 0 support gets provided, as you buy a license.
For home use linux distros are free.
Anyway, at this point if you plan on gaming, which I assume you are, then linux isn't really for you, yet. In the future it will though.
Arch Linux on Samsung 840 EVO 120GB: Startup finished in 1.334s (kernel) + 224ms (userspace) = 1.559s | U mad windoze..?
https://linustechtips.com/topic/68366-what-operating-system/#findComment-936829
I also want to know what I should get. I want to dual boot Windows with my Hackintosh, but I'm not sure which version I should get. Windows 7 or 8.1?
CPU: Intel Core i5 2500K | Case: Bitfenix Prodigy | Motherboard: GA-H61N-USB3 | RAM: Corsair 8GB 1333 MHz Video CardEVGA GTX 660 Superclocked 2GB DDR5
Power Supply: Corsair CX 430 | SSD: Samsung 840 120GB | HDD: 2X Seagate Barracuda 500GB 7200rpm | Monitor Asus PB238Q & Asus PB278Q
Mouse: Lenovo N50 | Keyboard: Apple Pro Keyboard | Operating Systems: Hackintosh OS X 10.8.5 & Windows 8.1
https://linustechtips.com/topic/68366-what-operating-system/#findComment-937882
Win8 +1
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
https://linustechtips.com/topic/68366-what-operating-system/#findComment-942627
Windows 8.
If you get Windows 8, you should come in with an open mind, and ready to face something different, if you go "aaaahhhaaAAA it's different go away! I don't have time for this..", then forget it.
On average, it seams to take about a month for people to get used to it, and learn it. After that they either like it, or prefer it over Windows 7.
It's just that Windows 8 has a steeper than normal learning curve, so you can't just get it to get it, you need to want it, or at least be open to change and give something new a serious try.
One things to keep in memory thaugh, the default layout of Windows 8 Start Screen sucks. But once you pin what YOU actually want/need, and sort from from most used at the bottom left to least used, or on your task bar already, to the right, then things will be easier.
Here is my start screen under Windows 8.0
As you can see, I pin my most accessed folders at the bottom left, and programs I use the most.
Well... here is the thing.. there is "use the most" where I open and close often... and 'use the most" where I use it a lot, but once started I don't close it until I am done. That is why my productivity programs are a bit further to the right.
That is my layout. If you are more gamer, you want to bring your game closer, of course. What's cool about it, is that you can have all your games, Steam, Origin, UPlay, all in one place in from of you. No need to start each program and look where your game is, and all that. Too many clicks. Here it's direct.
https://linustechtips.com/topic/68366-what-operating-system/#findComment-943784
I hear your call of indecision through the mist & shadows  :ph34r:  I also feel the pin prick of indecision of upgrading the new system I plan on building to 8.1 and deal with  inadaptable issues that will come up .or I can windows 7 hard decision to make. but for me right at this time its sticking with win 7  but on my new build  I am thinking of windows 8.1
https://linustechtips.com/topic/68366-what-operating-system/#findComment-943823
Windows 8/8.1 it's a bit more snappy and has dx11.1
https://linustechtips.com/topic/68366-what-operating-system/#findComment-943905
If you don't have a touch screen, Windows 7 is the only option that makes sense.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/68366-what-operating-system/#findComment-944262
