http://pcpartpicker.com/list/QvjgPs
The link above has what I have come up I know it not very good. The build will be used for Minecraft , Ark, cs go and more. The list must include all peripherals monitor, keyboard mouse and windows 10 to be induced into the budget. I would like to make the budget 700 but it has to go to 750 it should be fine.
https://linustechtips.com/topic/682321-budget-build-paning-help/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($204.99 @ Newegg)
Motherboard: Asus B150-PRO D3 ATX LGA1151 Motherboard  ($62.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR3-1600 Memory  ($39.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Video Card: Asus Radeon RX 460 4GB STRIX OC Video Card  ($135.67 @ B&H)
Case: Thermaltake Versa H22 ATX Mid Tower Case  ($35.99 @ SuperBiiz)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.97 @ Newegg)
Monitor: HP 22cwa 21.5" 60Hz Monitor  ($115.42 @ Amazon)
Keyboard: Cooler Master Devastator II Wired Gaming Keyboard w/Optical Mouse  ($29.99 @ Newegg)
Other: kinguin oem windows - around 30 dollars ($30.00)
Total: $736.49
Generated by PCPartPicker 2016-10-28 20:56 EDT-0400
https://linustechtips.com/topic/682321-budget-build-paning-help/#findComment-8772035
Id stay away from am3
Here is what id get
PCPartPicker part list: http://pcpartpicker.com/list/P8ZvZ8
Price breakdown by merchant: http://pcpartpicker.com/list/P8ZvZ8/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($110.99 @ SuperBiiz)
Motherboard: Asus H110M-A/M.2 Micro ATX LGA1151 Motherboard  ($49.00 @ Newegg)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($38.99 @ NCIX US)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Video Card: XFX Radeon RX 470 4GB HS Triple X Video Card  ($169.99 @ Newegg)
Case: Rosewill SRM-01 MicroATX Mini Tower Case  ($29.99 @ Newegg)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($84.89 @ OutletPC)
Monitor: Asus VS228T-P 21.5" 60Hz Monitor  ($99.99 @ B&H)
Total: $688.82
Generated by PCPartPicker 2016-10-28 20:57 EDT-0400
https://linustechtips.com/topic/682321-budget-build-paning-help/#findComment-8772044
I would drop the amd processor.
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/682321-budget-build-paning-help/#findComment-8772050
Total: $736.49
Here is what id get
Total: $688.82
Okay thanks for the help
https://linustechtips.com/topic/682321-budget-build-paning-help/#findComment-8772056
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: MSI H110M PRO-VD PLUS Micro ATX LGA1151 Motherboard  ($43.98 @ Newegg)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($39.98 @ NCIX US)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($44.99 @ NCIX US) get this later if you can't handle rebates.
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($24.99 @ SuperBiiz)
Monitor: AOC G2260VWQ6 21.5" 75Hz Monitor  ($119.99 @ Best Buy) for freesync support.
Keyboard: Thermaltake Commander Bundle Wired Gaming Keyboard w/Laser Mouse  ($28.99 @ SuperBiiz)
Total: $731.88
Generated by PCPartPicker 2016-10-28 21:15 EDT-0400
get OS from reddit for $20-30.
https://linustechtips.com/topic/682321-budget-build-paning-help/#findComment-8772086
