19 hours ago, TravisB said:
Hello,
I was wondering how I would go about removing the acrylic sheet from the pc case side panel on the Corsair 250D so I can paint the case? How would I do it?
Thanks.
They are usually held in place by just metal tabs that are bent over, to hold the window in place. Some others are screwed in place but not as common.
