Anti vibration fan mounts
FrozenFlame
Hi, I was just wondering if I can use anti-vibration fan mounts on 200mm fans. I plan to replace the standard mounting screws on the top 200mm fan on a Antec 1100 case.
I looked around online and found these....
http://www.amazon.co.uk/gp/product/B003QKUGZU/ref=s9_simh_gw_p147_d0_i2?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-2&pf_rd_r=0VYCXFRFQZ6HY1XDQ6E4&pf_rd_t=101&pf_rd_p=429454147&pf_rd_i=468294
http://www.ebay.co.uk/itm/PC-Case-Fan-Screws-Anti-Vibration-Noise-Reducing-Silicone-Rubber-Screws-x-4-/261298152832?pt=UK_Computing_Case_Accessories_Tool_Kits&hash=item3cd6956580
please let me know if they are any good or if you would like to recommend or suggest anything I'd be more than happy to listen and answer any questions.
thank you.
When is vibration a bad thing?
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
what do you mean? It's a bad thing because if the fan passes vibrations to the case it creates more noise, especially if you have a metal case. I'm trying to minimize the vibrations transferred to the case in order to reduce the noise.
I thought that was obvious.
My R4 also makes a lot of vibrations because of my rear exhaust, I am also planning on buying these rubberised screws. I think they'll help a lot. I'd say go for them.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
I've never been a fan of these rubber screws simply because they interfere with other components on my CM 690 II (I used to run Gelid fans that shipped with this kind of mounting, and they were quite effective despite being a PITA to install). I mean, I guess if you don't mind the interference then they'll work fine but in my experience, rubber grommets that go between the fan and the chassis work just as well and offer more flexibility.
http://www.frozencpu.com/products/3455/scr-07/Rubber_Grommet.html?tl=c111s202b77
Depending on where you are, shipping might be a tad on the high side. Else, I guess you'd be better off buying the rubber screws.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
I use Corsair fans. Quiet edition. You can get gasket washers from lots of places. Cork or/and rubber. Probably way cheaper than any specialty fan fasteners.
Most hardware stores have rubber washers and if not that most auto stores have small rubber grommets. Could save a few bucks. GL
Corsair 250d - - Delidded i7 4770k @ 4.4GHz (1.15v) - - Asus Maximus VI Impact - - Corsair h100i
Asus DirectCU II OC GTX780 - - NZXT x41 & G10 w/ Push/Pull Noctua IndustrialPPC's - - Corsair ax760i
16GB Corsair Vengeance 2133Mhz  - - Samsung 840 pro (boot) - - Samsung Evo (gaming) - - WD green HDD (data)
Those Ebay ones are better. I have both types, well another are bit longer.
Short ones aren't so sturdy and break if you move case even short distanses. They might work if your holes have smooth edges. However these do only little and I think something like 200mm fan doesn't vibrate as much as 120/140mm would.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
thank you.
Here.....only a couple of places I go to for those..
http://www.frozencpu.com/cat/l2/g47/c481/list/p1/Fan_Accessories-Fan_Mounting_Hardware.html
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=60_325&zenid=206ece34068f72c729ddf20ebda33de5
Case: Silverstone SG09B Motherboard: MSI Z10 Morter M-ATX CPU: I5-6600K  Ram: Corsair LP 2400 DD4 16GB GPU: MSI RX 480 Storage: Seagate HDD Baracuda 2TB x2, Crucial M200 500GB SSD X2 (Raid 0)PSU: Silverstone Strider Gold 1000W w/PP05E Kit
"When to say :blink: WTF :blink: ....$2K rig only used for Minesweeper and Internet Checkers marathons...."
