Connecting an external hard drive to a tv
Solved by johnny5c,
56 minutes ago, Felixwaw said:I have never used rasberry pi for anything before. Would it be able to connect to a tv using RCA cables, and be able to play any video format the external hard drive has?
It has both HDMI and composite (RCA) outputs so it'll work with any TV, here's the composite cable.
https://www.adafruit.com/product/2881
The RPi3 will play most common video formats, I even got 1080p h265 files to play smooth with a little overclocking but if you're using RCA cables you're limited to 480p.
