Just get Noctua fans :D
You can't go wrong with them. No need to worry about all the marketing BS or filters or whatever.
Just throw them in and you are good to go.
They aren't cheap tho... Not sure if that's a big issue?
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8727991
4 minutes ago, Joelbanks5 said:
So should I get static pressure fans if there's a dust filter? What's typically a good amount to spend on fans? What are fluid dynamic fans exactly and are they better than normal fans?
If you have very fine filtered intakes it wouldn't be a bad idea to use static pressure fans, as for the amount you spend it just depends on how much your willing to on fans basically. As for the fluid dynamic that is the bearing type, there are many out there with fluid bearings, Noctua's SSO regarded as some of the best.
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8727992
Can you elaborate more on the fluid dynamic bearings please?
also is it the more I spend the better fans I get or what?
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8727995
This explains it quite well the fluid bearing basically has the bearing surfaces that are suspended in a fluid to minimize friction.
http://www.gamersnexus.net/guides/779-computer-case-fan-bearing-differences
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8728017
Spending more is not automatically better as with everything. But Assuming it's from a decent brand, you can expect good performance while still relative silent and longevity and stuff like high warranty years. Noctua's are considered to be the very best fanmakers out there. But as with everything high end the cost for the extra performance and the worth of that for you is personal.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8728121
What's the best noctua fans that will work well with a dust filter in the way and ones that will work well withou a dust filter?
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8729051
Just normal Nuctua NF-F12's work fine in both cases.
You have of course different sizes. If you need a different size just let me know and i'll post the model of the ones you need to get :P
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8729677
Agree with @samcool55. But if you want a jet take the industrials :) They can go so fast.. But on low RPM they are also nice and silent and atleast in a normal non poop color.
PSU Tier list
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8730567
It depends on the dust filter and whatever else might be in the way.
Where are you planning to use the fan? Any reason why you're looking specifically at Noctuas?
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8731229
Plan on using the fans on my case which has a dust filter, and I'm looking at noctua's specifically because many people have said they're hands down the best
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8732134
What case and where on the case? There are also different types of dust filters. Did yours come with the case?
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8734468
I'm assuming you're looking for fans to use as front intakes?
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8734639
22 minutes ago, Joelbanks5 said:
Correct
NF-A14's or Silent Wings 3's would be excellent.
That being said, the included stock fans are already good--why replace them?
https://linustechtips.com/topic/678302-multiple-fan-questions/#findComment-8734677
