Hey guys.
I am pretty new to this forum and PC Building so forgive me for my wrongs. (I have just begun :p)
Anyways.
Topic 1 : PC Case building
I need some help, currently im building my PC, and i need a PC Case that looks cool/gaming-ish and also fit my specs down there.
And i live in indonesia so some parts might not be in here, or just too expensive.
Topic 2 : Help me build my specs
Currently im making my pc and heres the spec atm:
Case Segotep Lux
MotherBoard ASUS Motherboard Socket LGA 1151 [Z170-P D3]
Processor Intel Processor core [i5-6600]
GPU/VGA Gigabyte GeForce GTX 1060 Windforce
RAM CORSAIR Memory [Vengeance LPX CMK16GX4M2B3200C16R] 2 x 8GB DDR4 PC4-25600
HardDrive Seagate barracudda 1 TB
SSD Samsung SSD 850 EVO 250GB
HeatSink Cooler Master CPU Cooler Hyper 103
PSU RAIDMAX RX-600AF-B - 600 WATT, BRONZE
Monitor BENQ LED Monitor Gaming 21.5 Inch [RL2240HE]
I'm currently thinking of getting the iGame GTX 1080, from a review i saw, its apparently as good as the strix 1080 and the Galax 1080, but the problem is, it would be outta my budget, i also need some help on the Monitor, i was going to use the BenQ XLZ2411 (Is it???), but i changed it for lowered cost.
My Intent is for Gaming and editing, i Do not know how hard i will be editing. and i really don't need a huge perfomance, if its playable at good settings its okay, and no, don't even try changing my mind for going to AMD GPUs, i want Nvidia's Shadow play.
If theres anything i missed please tell me :) anyways thanks for your attention
-InVaderTech
P.S hey can you guys help me about this "signature" thing? it seems intresting. teach me the ways please xD
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/
Cases are personal preference, I mean find one you like that fits your needs, the nzxt s430 is good.
Upgrade the psu before you throw a gtx 1080 in there, a high end card with a low end psu will probabbly kill the psu, and possibly the card. If 1080p is your goal then even a 1060 should be fine.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723514
first off, godawful power supply, change that to something else first.
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723517
maybe get a 6600k because you are already purchasing a z board
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723522
Just now, InVaderTech said:
Thank you so much sir :) appreciate it
No problems, next time you can report your own thread (the triangle icon) and ask us to move it (only mods and admins can move or delete threads)
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723528
2 minutes ago, InVaderTech said:
I won't be OC'ing alot, but does it really help?
if you are going with the 1080, if not, their is no point getting a z board if you are not looking to overclock
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723537
There are lots of options, we have a thread about tiers, but in general Seasonics and XFX are good ones;
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723554
Just now, Oswin said:
if you are going with the 1080 if not their is no point getting a z board if you are not looking to overclock
i really don't need the 1080 at all actually, i only need a good enough Gaming PC, but having the 1080 would make me feel special :v, if i buy the 1080 i would need to abandon getting the CorsairK70 and get something else... and please suggest me a better mother board then :)
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723555
if you are not looking to overclock then go with a b150 or a h170 board save the money on something else, it will benefit. i dont really reccomend on buying very expensive peripherals because the system matters (mainly because it runs the whole thing) i myself are using cheap old peripherals just under $20
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723566
BTW the pc i'm gonna get will not be made by me, i will give the specs to the guy (or i would buy the parts and give it to him) and he will make it, FOR SOME WEIRD REASON, my parents told me that it would be okay that it will be built by another guy and he can raise the money like 10x or something, but they won't let me buy games from their money, i need to save up my self smh... anyways, i don't think a modular PSU would be necessary, But... i kinda want to display it on my desk if it would fit with my monitor...
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723587
then maybe go with this :http://de.pcpartpicker.com/product/nB3RsY/seasonic-power-supply-s12ii620bronze
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723591
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723607
7 minutes ago, Oswin said:
Ok i will end up getting the B150M-A D3, because if anything, those 2 were more expensive.
and also on topic of this weird thing, i will get the I5-6600K because the i5-6600 were 20$ more expensive :| Stupid indonesian sellers...
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723662
ow you live in Indonesia as well if you said erlier i could help you easily
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723669
how much does a 6600k cost their?
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723684
Actually i said i live in indonesia in the post xD Look at the Topic 1.
haha didnt saw it just skimmed, lazy reader
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/677857-pc-case-help-my-pc-specs/#findComment-8723686
