Take it out and put it back in. Make sure this time it's seated in the slot properly.
Main PC:
CPU: Ryzen 5 3600  | GPU: RTX 2060 | PSU:  | Memory: Corsair Vengeance RGB 3200Mhz 16GB | OS Drive: Western Digital Black NVMe 250GB | Game Drive(s): Samsung 970 Evo 500GB | Motherboard:  | Case: Fractal Design Define R6 | Monitor(s):  | Keyboard:  | Mouse: Steelseries Sensei 310
NASUS (NAS)
CPU: Intel Xeon X3440 | Motherboard: Super Micro X8SIL | Memory: 16GB DDR3 1066Mhz ECC UDIMM | HBA: Dell Perc H200 (Flashed to IT Mode) | Drives: 3x 16TB Seagate Exos x16, 2x 6TB Seagate Enterprise, 1x 6TB WD RED
RENEKTON (NAS)
CPU: Intel Core i5 4570TE | Case: Fractal Design Define S | Memory: 16G DDR3 1333Mhz SODIMM | HBA: LSI 1068E (Flashed to IT Mode) | Storage: 4x 3TB Hitachi, 2x 3TB WD RED
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8717734
Did you connect video cable to the 460? Did you connect power?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8717755
is it loose?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8717769
8 minutes ago, jol159 said:
No it is not loose
quote people so they know you replied
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8717809
  • 1 month later...
9 hours ago, jol159 said:
I managed to fix the problem a while ago. Sorry guys
How did you fix it? I'm having the same issue. I installed the card, built the computer myself with a i7 6700k, gygabite mother board. the monitor got the signal, but the comptuer slowed down so much, like it was lagging. I double checked the cables and that it was installed good and seated, but still nothing. The manual for the card said to disable the integrated graphics so i did that too, but it made it worse. Now it didn't want to detect the card and the computer wouldn't even start. Any ideas? I'm running the Sapphire Nitro RX-460 4gb OC version.
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8959293
My friend took the pc to currys and they managed to fix it (currys is a shop that sells tv's, pc's and laptops etc.) I don't know how they did it sorry
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8966479
But this was after we changed the bios settings from it using integrated graphics to the rx 460 which still didn't work. Then he took it to currys and they managed to fix it somehow
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8966487
Maybe call currys tech support if you live in the uk. Sorry for not being very helpful
Edited by jol159
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8966489
no worries, I will figure it out. I have a feeling its Windows 10 that's messing with it. After I got that update, my laptop has been acting weird and changing things and don't work. Its the reason I built the computer. But I thought having new hardware would change that, guess not. I've tried everything, but nothing has helped. Thank you though for trying. If you find out anything, let me know.
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8971070
Ok
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8971468
My 1060 was also dodgy before installing drivers. Did you install drivers?
That's an F in the profile pic
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8971543
6 hours ago, dorkiusmx said:
Yes, after i booted the computer, I inserted the disk that came with it.
The drivers that come on those disks are always horribly outdated. Go to the AMD or Sapphire sites and find the new drivers
https://linustechtips.com/topic/677374-problem-with-rx-460/#findComment-8984007
