Rx 470 frame stuttering?!
Go to solution Solved by timh1995,
Eh. I'm done trying with this thing. Nothing I do works. Its still in return period so I'm returning it and getting a gtx 1060 from pny. I don't know if its just amd slacking or MSI slacking or what but I'm gonna give nvidia a try. Haven't bought any of there stuff in a while
So I got my fiance a MSI rx470 8gb and its a great card...in some games. On some games it plays fine and dandy but then some games it stutters every 30 seconds or so. They are not new games that require a lot of GPU power so I know its not pushing the GPU too hard because she was playing these games fine on an r9 270x. Anyone have any idea what's causing the frame stuttering?
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/
What are the rest of the specs of his PC?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8716415
we need a bit more info. is it oc? power limit? what cpu? how are the temps?
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8716416
OK should've thought if that. I have 16 gigs of ripjaws ddr3 with an i7 4770 on a z97 motherboard. Temps never go over 70°c on the CPU or GPU. The GPU is in oc mode through the MSI program but it happens even when it isn't in oc mode. The CPU isn't ocd at all. Neither is the ram.
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8716426
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8716473
drivers up to date
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8716501
10 minutes ago, Carlos1010 said:
May I ask what games you are playing and at what resolution and settings?
11 minutes ago, GDRRiley said:
drivers up to date
Just updated drivers yesterday to most current and still happening. Games like resident evil, 7 days to die, GTA v have it happen. One game that it doesn't happen at all is dead by daylight and I don't think I've seen it happen on any battlefield game. All games maxed out at 1080p. We have also tried turning down settings in these games but it still happens with lowered settings.
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8716526
Windows up to date?
What power supply are you using?
Did you do a fresh install of the Radeon drivers when you installed the new card?
Intel i5 6600k @ 4.5GHz | NZXT Kraken X52 | Asus Maximus VIII Hero | Asus ROG Strix GTX 1070 | 16GB DDR4 Corsair Dominator Platinum @ 3200MHz | CoolerMaster MasterCase 5
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8718446
47 minutes ago, Zangashtu said:
Windows up to date?
Yes. Most up to date radeon driver. 550 watt cooler master PSU and windows 7 is up to date. No current updates through windows update available.
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8718660
Use DDU to wipe old drivers before you install new ones.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8720662
40 minutes ago, timh1995 said:
So you think I should completely remove the current drivers and reinstall them?
Yup, with DDU
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8721190
And just make sure that the temp target and max and Wattman arent' set too low or that the fan speeds aren't overly restricted.
CPU: i7 4770K  |  Corsair H80i  |  ASUS Z87-Pro  |  8GB Corsair 1866Mhz  |  GPU: MSI Gaming X RX 480 8GB  |  Corsair HX  750
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8721513
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8721839
This is what I was going to suggest hence my question but I got beaten to it :P
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8722756
  • 2 weeks later...
For anybody else coming from Google, I had the same issues with the RX 470 Red Devil. I lowered the power limit in Global Wattman until it stopped stuttering and switched the clockspeed to dynamic. Also turn power efficiency off in global settings.
Maybe these OC cards are trying to take too much power from the mobo, IDK.
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8788643
2 hours ago, slymeasy said:
For anybody else coming from Google, I had the same issues with the RX 470 Red Devil. I lowered the power limit in Global Wattman until it stopped stuttering and switched the clockspeed to dynamic. Maybe these OC cards are trying to take too much power from the mobo, IDK.
The motherboard can't limit it, they do consume more power than they should by the specification but its not setting on fire or at least melting plastic or crashing its unlikely power.
What is more likely is the usual thing, AMD has a history with stutter/microstutter issues and of late we have been seeing a lot of reports in certain games on Polaris. I would simply call it a driver issue, a fairly common one for AMD unfortunately. Its highly unlikely its all games, just 1 or 2 the OP is trying to play right now. If you play something a bit older and mainstream and still well benchmarked it'll probably run as its meant to.
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8788975
Update:
@BrightCandle was right here. The stuttering came back and I found that it's a variety of issues that were causing a bottleneck.
This is what I did:
- Excluded all game folders from my anti-virus. My anti-virus scans all files as they are opened.
- Used Razer Game Booster to suspend a lot of resource hog services in Windows 10
- Placed the stuttering games on the SSD.
The SSD alone didn't change a thing, but only after doing all of those different steps did the stuttering stop. Now I occasionally will hit a bottleneck with the CPU, but it's not the consistent stuttering that I experienced before.
https://linustechtips.com/topic/677256-rx-470-frame-stuttering/#findComment-8792608
