I have the Hyper 212 evo. The fins have a cutout with leaves a gap between the fan and the fins. I can feel what seems like a lot of air coming out of the gap and away from the fins. I don't have temperature issues but I'd like to optimize that situation.
Anyone seen this before/ fixed it?
Asus Z97-A
Intel Core i5 4690K 4.6ghz
Dual EVGA GTX 970 SSC 14030 Mhz
2x8GB Kingston HyperX Fury 1866 Mhz
CM Hyper 212 Evo
256GB SSD
500GB HDD
4TB WD Blue
Corsair HX 750i
Corsair 750D
https://linustechtips.com/topic/677031-hyper-212-evo-air-gap/
Its perfectly normal
That is designed to allow some air to escape and cool the VRM's and the mobo chipsets.
However, it is on both ends of the fan, and it has to be reversible.
I would not recommend messing with it, as it may cause strange noises.
Also, if you use tape or something, the adhesive will melt and probably ruin anything it touches
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/677031-hyper-212-evo-air-gap/#findComment-8713871
3 minutes ago, zMeul said:
yes I've seen it, fixing it .. haven't tried
try with some electrical tape - easy to remove if it doesn't do anything
The adhesive will melt
Roses are red
My name is Roy
https://linustechtips.com/topic/677031-hyper-212-evo-air-gap/#findComment-8713898
6 minutes ago, KickAHobo said:
What about the gap on top away from the cpu?
Feel free to experiment and tape up the gaps to see if it changes anything. There's no harm in doing so.
https://linustechtips.com/topic/677031-hyper-212-evo-air-gap/#findComment-8713981
They wouldn't have designed it if it would be better to have no cap...
I've used electricians tape on top of coolers bottom part. The one which is directly on top of CPU. Used to have thermal probe there reading ~10C lower temps than CPU. It was still sticky when I took those probes off the case.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/677031-hyper-212-evo-air-gap/#findComment-8717071
